      02-18-2018, 11:31 AM   #1
esevx5
Drives: X5
Thinking of switching from M1 0W40
will stick to the same
      02-18-2018, 12:12 PM   #2
335dsleeper
Drives: 09' 335d 10'35D
It’s only thinner when cold at startup, which is usually a good thing. Better cold lubricating properties. When warm, the 0w40 is thicker than 5w30.
Originally Posted by esevx5 View Post
Can anyone recommend an alternative? To me, the oil seems very thin compared to conventional 5W30 - but maybe I'm just over thinking it
I noticed a couple of oil drops on the driveway a few days ago, could that be attributable to the oil?
      02-18-2018, 01:47 PM   #3
RichardR0404
Drives: 2013 BMW X5 35D
I’m using liquo moly. Don’t use those but I do know castrol is garbage.
      02-18-2018, 06:56 PM   #4
Entr0py
Drives: 2007 X5 4.8i
So are you validating your choice to use moly by saying "castrol is garbage" ???
I mean, do you have anything to back that statement up ??
Are the engineers so stupid at BMW that they would not only use Castrol, but they print the brand name on their oil caps?
I don't get it, I just read "moly is garbage".
So which is it ?? .................. you have the floor Sir
      02-19-2018, 08:10 AM   #5
socale39
Drives: 04 545i SMG
The real question is what is the OP trying to accomplish? We can’t even start to help or provide sound advice without knowing the situation.
      02-19-2018, 12:03 PM   #6
omgboost
Drives: 2012 X5 35i
I'm assuming you're talking about the N55 engine? If so, the N55s are prone to leak oil due to the stupid oil filter gaskets and oil filter pan gaskets that they use. It may just be a coincedence that the oil is leaking when you changed oil types. I'm sure if you stayed with BMW branded oil, it would still leak due to the gasket failures.
      02-19-2018, 08:43 PM   #7
socale39
Drives: 04 545i SMG
What kind of oil you use has nothing to do with your leaks.
As for the oil concerns, the new Mobil 1 formulation apparently is even thinner but still approved through many manufacturers. If you want to stick with BMW approved oils make the switch to Pennzoil otherwise my opinion is that Mobil 1 will still continue to be a great oil. I’ve seen engines that have used Mobil 1 all their life vs other brands and I was amazed to see how clean the engine looked, like brand new. Knowing their formulations were just fine in the past, the slight difference for me doesn’t warrant a change IMO.
      02-20-2018, 08:06 AM   #8
philly42
Drives: X5M, Z3M
Do you normally get oil analysis done? I think this would help in deciding what oil to use. For example if the report shows your engine wear to be very low, it might be a good idea to stick with the current oil brand/weight. Two X5 owners with the same engine and oil can have different oil reports based on how the car is used. So until you get a report, you won’t know what oil works best based on the conditions the car is being used.
Think if it like this…it’s a good idea to take multi-vitamins. Though it’s better to get blood work done to get some data on an deficiencies, then make adjustments accordingly.
      02-22-2018, 04:17 PM   #9
smcnair
Drives: 2007 BMW X5 4.8i
152000 miles on 4.8. Always Castrol synthetic 5W-20. For what it's worth.
      02-23-2018, 08:34 AM   #10
heatmizr
Drives: E70 X5 50i M-Sport
Its thin so that it flows better in cold startup situations, where 98% of wear occurs.
Why would you not want this?
Also to be more energy efficient.
I think we have a lot of things to worry about rather than which of these fine oils is better than the other. Many other factors have a larger impact. Heat, mileage, oil change interval, usage pattern, etc.
My 2 cents.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      03-02-2018, 06:09 PM   #11
Jarhed1964
Drives: 2009 BMW X5 XDrive30 Sport
Hmmm.... I switched to Castrol 0-40 back in my E39 days and stuck with it. Has always quieted the engine down a bit. Plus the LL-01 spec. If I could find Moly over the counter, I'd give it a try. Just not convinced it's worth the extra money.
