03-21-2017, 05:51 PM | #1 |
Rep 347
straight pipe exhaust after DP's on X5M?
I did the muffler delete on the stock exhaust of my X5M, it sounds really good, not loud at all, almost an "exotic sound", my question is has anyone also had the what looks likes resonators removed and had straight pipe all the way after the DP's? if so, how is the sound?
03-21-2017, 06:23 PM | #2 |
FDNY Engine 55
681
Rep 2,115
Catless down pipes...straight pipes...H pipe...CF Akrapovic tips...no resonators...muffler delete...sounds like a helicopter
FDNY ENGINE 55...Liberalism: Find a Cure...http://www.xbimmers.com/forums/showthread.php?t=1127923
03-21-2017, 06:46 PM | #3 |
Rep 2,062
I don't know how muffler delete only sounds, but catless downpipes increased the cold idle sound and give a slight drone when the truck is trying to be lazy by forcing itself into 6th gear even though it's going uphill. Any other time, it's fine.
IBS spoke with M6Beast (creator of MSR) and after listening to his exhaust videos (search for them on YouTube), I'm in love. He said he'd likely never make an exhaust for us, but he did recommend that I replace my muffler with Vibrant resonators (it'll look like the Challenge when done), which use purchased and have yet to install. I'm also going to add an x-pipe since the S63TU engine has one, yet we don't. Last edited by m5james; 03-21-2017 at 06:56 PM.. |
03-21-2017, 07:21 PM | #4 |
Rep 347
03-22-2017, 02:55 PM | #5 |
Rep 347
Well I had the resonators removed, so after the stock DP's its all straight pipe but no real difference from when the mufflers were removed, not loud at all, still really tame sounding. The 16 Mustang GT I traded in for the M was crazy loud with straight pipes after the cats... I guess catless DP's and JB4 is next :-/
03-22-2017, 06:33 PM | #6 | |
FDNY Engine 55
681
Rep 2,115
03-22-2017, 08:11 PM | #7 |
Rep 347
03-22-2017, 10:08 PM | #8 |
Rep 2,062
There's a hardline that runs the length of the car and starts at the passenger side of the engine bay and changes to rubber before going to the muffer valves. Look in the engine bay and you'll see the hardline transition to a rubber line and feeds into a few T's behind the vacuum canister. Simply remove one of the T's, coil up the rest of the vacuum line into the fender and save yourself the headache in case you ever get reduced power warnings for a vacuum leak...that long line is where mine had an issue.
03-22-2017, 11:05 PM | #9 | |
Rep 347
03-23-2017, 05:21 AM | #10 |
FDNY Engine 55
681
Rep 2,115
My bad, I could of sworn I read you were thinking about doing the muffler delete...I should of scrolled up lol
03-23-2017, 06:11 PM | #11 |
Rep 449
You should have posted videos with just the muffler, and you should post one now as the truck as. It could give me a good peak at what I know I will end up doing one weekend when I get bored.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD 1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about 1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter |
03-23-2017, 06:15 PM | #12 |
Rep 2,062
03-25-2017, 05:17 AM | #13 |
Rep 347
03-26-2017, 07:10 AM | #14 |
Rep 449
thanks man. Its not like not having a sound clip is going to stop me from hacking that thing off. Its in such an easy spot to remove. Then I shall see how I feel about the noise, if I like it, I will get a shop to run some pipe into the stock tips in the stock location, and keep it moving.
