      03-20-2017, 12:22 AM   #1
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
2012 X5 Aux Fan?
Took my car to the shop for an overheat warning, had the water pump and tstat changed and the alarm came back up. I have seen this as a common issue on all previous generations but havent seen many on this model. I have around 95k on this car just wanted to see if anyone has had this issue.
Thanks,
      03-21-2017, 11:10 AM   #2
Bklynjoker
Bklynjoker's Avatar
85
Drives: G20 %E2%80%9C22%E2%80%9D MSpor
"11" 3.5i 81k and mine is in service since yesterday(mon). Warning over the weekend of over heating the 2nd message was overheated results in no throttle. Days before this I was hearing the fan or electric water pump go on for no reason, it was bugging out. This is a common problem with BMW & no recall yet
I'll keep updating once I receive a call from service
LeXxiNGToN aka LeXxDiAMoNDS
      03-21-2017, 12:21 PM   #3
Bklynjoker
Bklynjoker's Avatar
85
Just got a call from BMW. $1300 water pump & thermostat. If you have warranty get it fixed
      03-30-2017, 12:46 AM   #4
svt1998gt
Thanks, i had that already changed at around 90k, i had the fan changed and used the following part number - https://www.advantagebmwparts.com/oe...PiSRoCvPDw_wcB
The part number is supposed to be a replacement of an older part that is still on some sites which is a few hundred cheaper.
The labor on its own was cheap, the part at local dealerships are around 900 to 1000 bucks, i looked online and found an online store in Houston that 2nd day shipped it for around 700.
Car is running fine, i am not hearing the fan whine as loud.
Also it seems when the overheating would start, the AC would stop blowing cold air.
