      03-19-2017, 05:57 PM   #1
friendlystart
Drives: X5i M-sport,E24 M635i,E34 535i
N63 air box removal
Plan to replace spark plugs today but ran into a snag. After removing intake ducts and hot air film sensor I come not maneuver the air box out of the engine compartment Is there a trick here that I am missing. Search the site and found one link unfortunately the pics are no longer available.
Thanks
      03-20-2017, 07:43 AM   #2
DIY_Nation_TH
Drives: 2009 BMW X5 4.8I
Diy_nation_th on youtube has spark plug DIY on 4.8i. There is one or two bolts under the air filters that need removed.
      03-20-2017, 10:32 AM   #3
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
I just pulled mine this weekend to do a downstream o2 sensor. I removed the cowls on both sides, there are 3 bolts in the back that are tricky to get to. So take a 13mm socket, turn the plastic keepers half a turn, pull the upper portion of the cowls by the wipers out, then remove the lower portion, with a few hex head bolts and some torx head bolts, then you should see the bolts you are missing for the air box to be removed. You don't have to remove the brace bars in the process. I can take pictures late today if you don't understand what I mean.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      03-20-2017, 01:21 PM   #4
friendlystart
Thanks for your help!
      03-21-2017, 11:58 AM   #5
JoeyBimX5din
You're welcome, did that do the trick?
