      03-04-2013, 04:45 PM   #1
Gutenguy
Drives: F10 M5.
Wheel (clarification) Question..
Hello all.. so, Im looking to swap out the current (style 227) wheels on my 09 X5 Msport (which will soon be up for sale) with a set of x6M or even x5m wheels.. I was told by someone that this cannot be done due to the bore of the wheels or something along the lines of that.. Can someone please chime in and clear this up for me? I know there are a few members on here that have done it..
      03-04-2013, 09:55 PM   #2
n3985
Drives: a car
You need wheels with 74.1mm center bore. If the wheels are 72.56mm you can buy adapters to make it fit.
      03-04-2013, 10:10 PM   #3
Gutenguy
Drives: F10 M5.
I see.. Any links on where to find those / what they look like?.. Not very familiar with them..
      03-04-2013, 10:28 PM   #4
Devimik
Devimik's Avatar
Drives: 2018 X5 35i Sports Activity
They look just like spacers, but 20mm and you bolt the adapter to the hub and the wheel to the adapter. There are also versions that come with longer bolts, so you bolt the wheel and adapter to the hub with one set of bolts.
http://store.allsprings.com/bmw-5x12...0mm-p2935.aspx
      03-05-2013, 08:10 PM   #5
Gutenguy
Drives: F10 M5.
Oh ok.. anyone have any experience with this type of setup? Also will the 2011+ Msport wheels fit directly onto the 09-10 or will this adapter apply to both setups?
      03-06-2013, 12:59 AM   #6
Sylvan Lake V35
Vanilla Gorrilla
Sylvan Lake V35's Avatar
Drives: X5M & X5 35d
You can get M replica wheels that have the correct hub bore or even get the rear M wheels machined to 74.1mm.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
      03-06-2013, 10:25 AM   #7
mlee4984
Slow M3 Driver
mlee4984's Avatar
Drives: 2014 M5 ZCP
From the research I've done, all E70 X5 wheels including M Sport are interchangeable. X5M, X6 and X6M all share the same bore size for the rear. Please correct me if I'm wrong.
Mike
2014 Citrin Schwarz Metallic M5
2005 Interlagos Blau Metallic M3
      03-06-2013, 12:15 PM   #8
Sylvan Lake V35
Vanilla Gorrilla
Mike
You're correct E70 have a 74.1mm hub bore all around, X5M/X6M/X6 have a 74.1mm front hub bore and 72.56mm rear hub bore.
      03-06-2013, 03:33 PM   #9
Gutenguy
Drives: F10 M5.
So I assume its safe to say that the newer 2011+ Msport wheels will fit just fine but, the 5 and 6Ms wont..
      03-06-2013, 07:32 PM   #10
Sylvan Lake V35
Vanilla Gorrilla
Correct.
      03-07-2013, 01:52 PM   #11
Gutenguy
Drives: F10 M5.
Can you machine wheels to be a smaller hub bore? (hope thats not a stupid question)
      03-08-2013, 12:12 AM   #12
Sylvan Lake V35
Vanilla Gorrilla
No you can only get them machined larger, you can get a hub centric ring that allows larger bore wheels to fit smaller bore hubs. Usually good tire shops sell them they can be metal or a hard plastic I have used both and both work fine. Lots of people run without them, there is a risk of the wheel wobbling a bit because the lugs are now centering the wheel not the hub.
      03-08-2013, 06:34 AM   #13
Gutenguy
Drives: F10 M5.
from what ive been told, the x5/6M wheels have a smaller center bore thus need to be bored out approx 2mm to fit the x5.... can anyone else confirm this?
      03-08-2013, 10:11 AM   #14
dkreidel
dkreidel's Avatar
Drives: a lot of BMW's
Did you read post #8?
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option
      03-09-2013, 10:49 AM   #15
Sylvan Lake V35
Vanilla Gorrilla
You can get the M wheels machined/bored out to a larger size to fit the E70.
      03-11-2013, 07:32 PM   #16
Gutenguy
Drives: F10 M5.
Ok this def cleared it all up.. As for the fronts can anyone tell me what size (mm) bolts i will need with 15mm spacers?
