Step-by-step coding CCC to CIC+Combox retrofit coding instructions
Can someone please post step-by-step coding instruction to retrofit CCC to CIC+Combox for X5 E70 and X6 E71. In other words, what needs to be added to the Vehicle Order (VO) in FRM and CAS and what parameters need to be enabled for CIC and Combox and in what modules. Also, what parameters in which modules need to be adjusted so that NAV instructions voice maximum volume (limit) is louder than normal with LOGIC-7 Top-HiFi sound system. For some reason it is fine with CCC, but with CIC maximum volume limit is way too low (too quiet). Thank you in advance any feedback on this one ...
