03-04-2017, 06:03 PM | #1 |
Rep 728
X5M Turbo Blankets
Hey guys,
I was looking for a cheaper alternative to the PTP blanket and wanted to try individual ones. Found thermal zero's T25 blankets that I thought might fit so I ordered a pair. I changed my spark plugs today and wanted to test fit a blanket. They kind of fit...it took patience and time to actually get one on a turbo since there is very little space. My only concern is the wastegate actuator which may get some resistance from the blanket; is that super bad? I can still move the actuator arm with my middle finger but difficult with my index finger. The blanket appears to pinch a bit on either side. I would need to pull the downpipes to secure them properly as there is no room otherwise. I have some catless DPs in the mail so I figured it was worth holding onto both blankets until I install those and give it a whirl. You can't return the blankets after test fitting, there is a seal on the bag. So I already have sunk cost in one of them...if it fails I guess I'll sell it on craigslist and return the other one. What are your thoughts? Here is the blanket on one of the turbos: This picture shows the blanket pressing on the adjacent waste gate arm:
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
03-05-2017, 08:14 PM | #3 |
Rep 728
03-06-2017, 06:14 AM | #4 |
*May contain nuts
193
Rep 286
03-06-2017, 09:05 AM | #5 |
Rep 728
Reduce heat related wear on the hoses in the engine bay.
03-06-2017, 02:44 PM | #6 | |
Rep 994
reduce radiant heat under the bonnet by a large degree there is a university backed paper that there is a HP gain with turbo blankets The first one alone, should be HUGE to just about any performance enthusiest. Reduce underhood heat, prolong the life of many other neighboring components, but a minimal/slight/notevendetectable chance of making more power or spooling sooner. Why not? I'd grab some galvanized wire, like the kind used for outdoor fencing, and tie it around the blanket, to compress it and give your wastegate rod a little more wiggle room, if it really bothers you. But think about how strong that spring is in opening the wastegate, that I don't think it's that big of a deal.
jandref321345.00 |
03-06-2017, 04:59 PM | #7 | |
*May contain nuts
193
Rep 286
If you're worried about the heat, you're better off ceramic coating the housings (and downpipes while you're at it). |
08-14-2017, 11:26 AM | #8 |
Rep 138
Hi
Are you happy with the performance of these turbo blankets, would you recommend putting these on a BMW X5M. It seems you had to remove the OEM heat shield to install the blanket. Is it worth the effort. I checked with PTP and their blanket can be installed inside or outside the OEM heat shield. Someone installed it over the OEM heat shield. Is it worth spending money and effort and I am not sure if this affect the warranty as well. |
08-14-2017, 11:58 AM | #9 | |
Rep 138
Are you against the use of Turbo blankets. I am only concerned about the warranty aspect,
08-14-2017, 01:00 PM | #10 | |
Rep 994
You gotta pay to play. If you're concerned about a warranty, you shouldn't be modifying a car. Or only buying BMW/Dinan approved parts. There is strong anecdotal evidence, and millions of miles logged for PTP turbo blankets and similar, where there isn't increased anything wear/failure/etc. Only benefits.
08-14-2017, 01:06 PM | #11 | |
Rep 138
Is it even considered a Mod, how can they confirm if the Turbo cracked because of excessive warranty. my car is bone stock and I haven't tried anything as part of modifications. My question was more about the usefulness of the Turbo blanket. on the X5m it sits on top of the OEM heat shield so it should be a pretty easy installation. Do you have these installared in your Car.
08-14-2017, 02:20 PM | #12 | |
Rep 728
I bought the individual blankets and catless Downpipes. I can't really say if the temps reduced at all. The bay still gets pretty hot and I pop the hood when I get home and leave the garage door open to allow it to cool down. It's also a pain to install the individual blankets since they're so large. Only one company sells the smaller t22 blankets and they are $250 each which is the same price as buying one PTP blanket. |
08-14-2017, 02:25 PM | #13 | |
Rep 138
I wouldn't mind paying extra for the quality. Which brand you installed and is your car also a BMW X5M. I checked with PTP and their blanket is on back order and will only arrive in September.
The PTP one can be installed over the OEM heat shield, so I think the installation may be fairly simple. My only concern is that the warranty on the vehicle may get void. Quote:
08-14-2017, 03:10 PM | #14 | |
Rep 728
I have a 2012 X5M and installed Thermal Zero T25 blankets on it. The turbos on the X5M are GT22s so very small. The blankets I bought barely fit, and I had to tighten them down with exhaust wrap ties. Then it was kind of a pain to reinstall the heat shield. The individual blankets I bought were $100 each so I paid $200 total vs $500 PTP blanket. Like I said, if you have the cash then the easy right answer is PTP. Just go to your truck, pop the hood, take off the plastic rear engine cover and you can see right where the blanket would go. You would need some internal torx bits, an extension or two, a 10mm socket, a O2 Sensor socket, and torque wrench. Go to the link below and follow pages 14-19. Too easy http://www.hotcarparts.de/bilder/Akrapovic/EBA/X5M.pdf
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs Last edited by jandref321; 08-14-2017 at 03:12 PM.. Reason: added a few words |
08-14-2017, 03:25 PM | #15 | |
Rep 138
jandref321, Really impressed with your knowledge and your helping attitude You are an asset to the bimmer community. The PDF is really informative.
I contacted PTP and they still dont have the S63 blanket in stock so the project will go on hold. I dont want to mess up with anything by trying to remove the OEM heat shield. My best bet is to install it over the OEM heat shield. I already popped the cover to see what do I need. The TIS link was also helpful:: https://www.newtis.info/tisv2/a/en/e...ntrol/ByN67Hsz Do you think removing O2 sensor is required if I install it over the OEM heat shield. I might leave it like this, I have an exclusionary warranty paid 11700$ for 4 years. Never seen the temp of the car go beyond 210 so seems I am worried without a reason. I am still a newbie and learning more about my car. Did you see the pic of the over OEM heat installation that I shared before. Quote:
08-14-2017, 11:04 PM | #16 | |
Rep 728
People normally put the blankets on to reduce engine bay heat and prevent heat damage to the vacuum/coolant lines. The heat cycles end up hardening and cracking the rubber prematurely. You wouldn't see those effects from the oil temp gauge. The cooling system should be solid.
08-19-2017, 03:26 AM | #17 |
M-Power Dallas !!!!
50
Rep 323
Drives: 01 Custom HPF 900whp Turbo M3
I guess i got lucky
they are in stock now! jumped on PTP website, emailed them asking if they offer a military discount, they did, she gave me the code after i provided them my proof of service, used the code to get the custom S63 blanket and it shipped out and delivered the next day from Austin, Tx up to Dallas, Tx
Leonel aka Rico /// BMWCCA # 403748
10 X5M - Pure Stg.2 turbos/K&N/JB4/Becker 3" Catless DPs/Megan Racing Ti Exhaust/H&R/Rohana RC22s/Vrederstein Ultrac Sessanta/Soon/+BMS+KWV3s+OSSDesign headlights..... |
08-19-2017, 09:03 AM | #18 | |
Rep 138
Also do you plan to install these over OEM heat shield which will be much easier install , please share some nice pictures of the install including the mechanism you use( spring or wire) as it will be really helpful. BTW, I sent PTP A note inquiring about availability again Last edited by coolmayank; 08-19-2017 at 09:11 AM.. |
08-19-2017, 03:22 PM | #19 | |
M-Power Dallas !!!!
50
Rep 323
there military discount was 8% off since im installing my new Pure Turbos stage 2 kit, there going on the actual turbo housing not the shields I'll share the Pics JPeuro sends me for sure!
08-19-2017, 04:55 PM | #20 |
Rep 138
I was kidding when I asked your blanket, they told me that you placed the order for the last one in stock on 14th august. I will wait it's not too far . Don't forget to share the nice pics of installation as it will be great help .
08-19-2017, 09:07 PM | #21 | |
M-Power Dallas !!!!
50
Rep 323
i hope they video record the install but if pics are all they share, i will share them. i also asked the actual tech to give me his take on the install of the pure stage 2 turbos and the blanket i have not chosen a tune yet, to go on before the JB4+BMS is installed but when i do, it will be time for my X5 ///M to get her own build thread
08-23-2017, 04:10 PM | #22 |
Rep 138
Have you completed the install, I was curious if you can share some pics/video
Tags |
blanket, heat, temperature, turbo, x5m |
