      02-27-2016, 02:09 PM   #1
Cattivo
FDNY Engine 55
Cattivo's Avatar
Launch Control X5M
I'm curious as to see if anyone else running a tune(stage 2+) and catless downpipes are able to effectively use their launch control without any issues...my main problem since installing the tune is even with new cross drilled rotors and a new set of brake pads(OEM), while attempting to use launch control the brakes are not holding the truck in place...the truck keeps lurching forward...too much hp/torque???
I'd like to try and resolve this issue so I can use the launch control at the drag strip in the near future...any advice is greatly appreciated
      02-27-2016, 06:15 PM   #2
Dr.Duct_Mossburg
Dr.Duct_Mossburg's Avatar
59
Drives: Space Gray · E70 X5M
No issues here. I creep the RPM up while pushing the brake hard to the floor.
      02-27-2016, 11:56 PM   #3
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
no issues either, just make sure you floor the brakes all the way first with left foot before applying throttle
      02-28-2016, 04:39 AM   #4
Cattivo
FDNY Engine 55
Cattivo's Avatar
I pressed the brake pedal as hard as I could down to the floor but it still lurches forward...I also tried to bring the rpm's up gradually till the flag appears...same results
Prior to installing the tune I was able to use launch control without any issues...I'm wondering if it's possible to install a trans brake for track days
      02-28-2016, 07:05 AM   #5
Dr.Duct_Mossburg
59
Stop skipping leg day ??
      02-28-2016, 08:02 AM   #6
jrmccain
jrmccain's Avatar
Drives: 2022 M5C
I would check and see if there is any air in your brakes. Bleed the lines one more time.
      02-28-2016, 12:54 PM   #7
Cattivo
FDNY Engine 55
Cattivo's Avatar
I was just talking with another BMW enthusiast at the car wash and he suggested the same thing
      02-28-2016, 12:57 PM   #8
Cattivo
FDNY Engine 55
Cattivo's Avatar
Tore both acl's but I still manage to do legs twice a weak
      02-28-2016, 02:25 PM   #9
Dr.Duct_Mossburg
59
Hey man... I know how you feel... go in to surgery on the 18th for a torn ACL and Meniscus.
      02-28-2016, 04:54 PM   #10
Cattivo
FDNY Engine 55
Cattivo's Avatar
My best advice to you would be... post surgery make sure you get a CPM(continuous passive motion) machine to help with the inflammation...I was on a call and fell through the roof of a building and tore both acl's at the same time. Good luck on the 18th brother
      02-28-2016, 05:44 PM   #11
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
you have an issue no way the engine should over power the brakes. do a bunch of hard stops and make sure the abs comes on.
I didn't know I couldn't do that. But I did know I couldn't do that.
      02-28-2016, 05:47 PM   #12
infamousdiz
you mean pushing the beds together at work, we are the pole smokers, you know we come down pole so quick that the pole is smoking. dennis leary
atleast rescue me had the fire house antics right.
      02-29-2016, 02:52 AM   #13
Cattivo
FDNY Engine 55
Cattivo's Avatar
I'll give that a try on my way to work...I'm also going to bleed the brakes today as well, hopefully that will resolve the issue...thanks brother
      02-29-2016, 02:58 AM   #14
Cattivo
FDNY Engine 55
Cattivo's Avatar
That was a great show, still beats all these other pretentious smoke eater t.v. shows
