      01-08-2016, 09:39 AM   #1
Qarban
Drives: E70 X5 and E70 X5M
Exclamation X5 Starting Problem
Video of wife's 2007 X5 3.0si starting problem. Any idea what might be the problem? Coils? Plugs? Fuel pump? Plugs were changed last year
This happens randomly, mostly when the engine was not started for more than 24 hours. The engine turns on but turns off immediately so I assume it is not battery or ignition problem. The engine stays on only when I step on the gas pedal (and keep on stepping) while starting the car.
      01-08-2016, 10:13 AM   #2
BU Z4
Drives: Big & Small
I would start checking with coil packs and plugs.
      01-08-2016, 10:42 AM   #3
Qarban
Thanks BU Z4, I will have them checked
      01-08-2016, 11:02 AM   #4
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
Did you check for codes? Idle control valve? Fuel filter?
      01-08-2016, 01:37 PM   #5
Qarban
No CEL on. I will have the fuel filter and idle control valve checked too
      02-24-2016, 12:57 AM   #6
Qarban
Problem was already corrected, yay! Active Motorwerks in Austin changed the valve cover, no more hard cold start since! They detailed the engine bay too for free! Picture attached for attention!
