Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Problems with n54 335i
      02-04-2014, 01:27 PM   #1
Biely
Biely's Avatar
Belarus
Drives: BMW 335i
Greetings from Belarus!
The problem is like this - check engine regularly appears on the panel. Consumption increases, reduced dynamics, sometimes raises the idle speed or just shaking a little. I have two errors - lambda before catalyst (mixture too rich) and after the catalyst (mixture too lean). Both lambda in the first bank. No more mistakes. Exacerbated if the ride is very active.
Any ideas what's wrong? The catalyst?
      02-04-2014, 01:55 PM   #2
klepikovp
klepikovp's Avatar
10
Drives: 2008 BMW 335i
o2 sensors?
      02-04-2014, 02:27 PM   #3
Biely
Biely's Avatar
Belarus
Drives: BMW 335i
No, they are working quite good. I've tried to install different ones - the same issue.
      02-04-2014, 02:58 PM   #4
crypticc
Drives: e92 M3 DCT + Comp
Switched sensors after a downpipe install? Sorry, not an expert just seem that question answered for similar issues.
      02-04-2014, 03:26 PM   #5
Biely
Biely's Avatar
Belarus
Drives: BMW 335i
I have stock pipes with cats.
      02-04-2014, 07:33 PM   #6
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
Scan car for codes and post up, could be a number of things..
2008 E90 335
      02-04-2014, 08:53 PM   #7
Miller335
Drives: 2007 E92
Could be many things.
O2's, one of your cats, a misfire due to plugs/coils/injectors throwing things off.
      02-04-2014, 09:35 PM   #8
JazStar740
JazStar740's Avatar
11
Drives: 2011 E93 335is/1994 E32 740iL
Are you using 91 or better fuel? Also you mentioned downpipes, did the check engine light begin after the downpipes?
2011 E93 335is / BSM / Coral Red / 6MT / NAV / HK L7 / BSW Stage One / SWS8's
1994 E32 740iL / Black / Black
2008 E85 Z4 / Stratus Grey / Dream Red *SOLD* / 2006 E90 325i / Jet Black / Black *SOLD* / 2001 E53 X5 / Silver / Grey *SOLD*
      02-06-2014, 04:25 PM   #9
Biely
Biely's Avatar
Belarus
Drives: BMW 335i
Using only 95 fuel. I have no downpipes. I have stock pipes with cats.
As I said before I have two errors - lambda before catalyst (mixture too rich) and after the catalyst (mixture too lean). Both lambda in the first bank. No more mistakes.
      02-07-2014, 02:46 PM   #10
BOOST3D
BOOST3D's Avatar
Armenia
30
Drives: 328i 2000,X5 2003,2008 335i
It sounds like the places for the o2 sensors are switched on bank one
Tags
335, 335i, cat, e92, n54
