      06-25-2015, 07:50 PM   #1
JTZL
Drives: 2010 X6 E71
Retrofit ///M Speedometer Cluster for X6 E71
Is it possible to just hotswap the speedometer dials?
I have a RHD E71 X6 and would like to know if it is possible to just replace the dials on my existing speedometer cluster with the ///M dials.
Has anyone done this mod before?
      06-30-2015, 07:17 AM   #2
hellomyBMW
Drives: 2012 BMW X6 50i
Not sure if this is possible... Or at least I haven't seen a cluster retrofit. It would be cool to see one though.
It may physically fit but I would think there is more involved than just swapping the cluster since M models have more features
      07-09-2015, 06:12 PM   #3
dy63
Drives: F30
you can swap the face and needles but you will still have the orange led's on your standard one unless you solder white led's onto your standard one. if you plug the M speedo into your car i dont know if it will work ok or not
      07-11-2015, 06:38 AM   #4
Patrys@BimmerTech
Poland
620
Drives: 2007 E92 335i
Yes, it can be done, but the M cluster has to be programmed for your VIN and mileage first.
      12-28-2015, 11:40 PM   #5
Alpin3_F30
Euro.Techniks-EAST
Alpin3_F30's Avatar
Drives: 2015 F30 328i
not always. i retrofitted an M cluster on my e92 3 series and it picked up my mileage. maybe just lucky i guess
      12-29-2015, 07:14 AM   #6
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
Drives: M3 COMP
I swapped mine couple months ago miles stay the same as that is already saved on ur computer but it will trow u some lights I believe it needs some type of codding.
I didn't attempt to code so I put my original back in place and left it like that
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
      01-04-2016, 02:48 PM   #7
NASCAT
Drives: 2014 E71 X6 M Sport
Doesn't the M cluster also display the trans mode & what gear you are in differently?
      01-23-2016, 03:29 PM   #8
Gatoferoz25
BeastM3r
Drives: M3 COMP
Any updates ?
