      04-08-2023, 04:53 PM   #1
Chrisnytx
Chrisnytx's Avatar
Drives: BMW X5
2013 BMW X5  [10.00]
Over torqued Oil Filter Housing
Greetings,
I was conducting a regularly scheduled oil changed on my n55. I picked up a new torque wrench from harbor freight (my nicer torque wrench doesn’t go as low as 25 nm). I started to tighten it by hand and then went to verify the torque with my torque wrench but then it slipped off and I realized I over tightened my oil filter cap. I tried to take it off but it seemed like it will require some elbow grease. Since I don’t have a spare on hand, I don’t want to force it incase it’s broken and can’t be put back on. I finished up my oil change and turned on the car to verify the oil level and everything seems to be working well.
My question is, is this something I will have to fix on my next oil change? Or should I be worried and try to fix this ASSP.
Thank you for your time!
Last edited by Chrisnytx; 04-08-2023 at 05:07 PM.. Reason: I accidentally said oil filter housing but I meant oil filter cap
      04-08-2023, 11:02 PM   #2
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
fix on the next oil change, check for cracks, replace, cheap part to replace or get the billet one from ECS tuning (metal vs. plastic)
      05-07-2023, 09:18 PM   #3
Chrisnytx
Chrisnytx's Avatar
Drives: BMW X5
2013 BMW X5  [10.00]
Just knocked out my next oil change and there's no damage as I might've expected. Is a billet cap significantly better? It always looked to a piece of accessory vs function.
