03-18-2021, 11:23 AM | #1 |
Rep 192
Valve Stem Seal Repair
So I'm going to do the valve stem seal repair on my M E71.
I have been waiting for this time for years. Here's the kicker. I can upgrade my coils, Fuel injectors index 12, crankcase and a few others just by paying for parts. No labor. BONUS!! I am also re-doing my suspension as well. I wanted some insight on any additional repairs I should do so I can do everything at one time. I wanted to change my: •wheel bearings (I hear a whining noise when I reverse at times) •change my belts(which ones if any) (Item #S is not needed as my turbos are good.) •fluids? I want to refresh my car give it second life. Please community all suggestions accepted. Thank you! |
03-18-2021, 12:27 PM | #2 |
Rep 60
Engine out? Could be good time to check rear main seal and upper/lower oil pan gasket. Also, the coolant hose that lives in the valley of the engine (the one with with the y-connector).
03-20-2021, 02:26 PM | #3 |
Rep 219
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
I second on replacing the coolant Y engine valley hose. Once it fails, it can threaten the Alternator and send coolant fumes into the cabin.
Too__Hu///Mble98.50 |
03-20-2021, 08:10 PM | #4 |
Rep 265
I'm planning to do something similar to my E70 X5M. Do you happen to have a part number for the hose?
IG @E70_XRatedM | YT: E70M Garage
03-22-2021, 03:16 PM | #5 |
Rep 192
03-23-2021, 05:19 PM | #6 | |
Rep 60
There's also this thread for reference. https://www.xbimmers.com/forums/show...ht=17127589731 |
04-09-2021, 12:27 PM | #7 |
Rep 219
