The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > SP DATEN 53.3 (August 2014)
      08-10-2014, 11:01 AM   #1
danmcq
danmcq's Avatar
14
Drives: 2015 335i xDrive M Sport
Arrow SP DATEN 53.3 (August 2014)
SP DATEN 53.3 Full (not lite) is now available.
https://kickass.to/bmw-sp-daten-53-3...-t9436437.html
      08-10-2014, 02:00 PM   #2
cryptomit
Drives: 320d 2012
Thanks for sharing.
      08-11-2014, 01:15 PM   #3
MiniXP
MiniXP's Avatar
69
Drives: 08 335i, 06 X5 3.0
will this make everything in INPA appear in German?
Most of mine shows in English right now, I remember last time I updated something on it it switched to German? Will this cause that to happen?
http://www.e90post.com/forums/signaturepics/sigpic228641_1.gif
      08-11-2014, 01:20 PM   #4
danmcq
danmcq's Avatar
14
If this does happen after updating, change the following in your INPA.ini
Original line:
LANGUAGE=DEUTSCH
Modified for English:
LANGUAGE=ENGLISCH
      08-11-2014, 02:01 PM   #5
ferocity02
Drives: 2013 135is
Are there any downsides to updating to the newest SP-daten?
      08-11-2014, 03:27 PM   #6
Sensible_
Drives: 2008 E90
Thanks danmcq!
      08-11-2014, 03:36 PM   #7
danmcq
danmcq's Avatar
14
Don't take my word on this, but as I understand it, your DATEN files can never be too new, but they can be too old (out of date).
      08-11-2014, 03:52 PM   #8
ferocity02
Drives: 2013 135is
I see. So on the flipside, what are the downsides when the sp-daten files are too old?
What does one gain by using the newest files?
Sorry for the noob questions, very new to coding.
      08-11-2014, 04:30 PM   #9
Sensible_
Drives: 2008 E90
Like any computer the software can have bugs or glitches or not perform as desired. Occasionally due to customer feedback / reoccurring faults / FASTA diagnostic data / performance requirements / emissions data / fuel economy... BMW tweak the ecu firmware. These small changes are often advantageous to customer and or BMW.
The most recent major one I can think of is the CAS module update which prevents thieving bast*rds with cheap key programmers from programming a blank key and driving your car away!
Once your modules have been updated by ISTA P 2.53.3 for example at a dealer or Indy or indeed at home if you have the kit, You'll need 53.3 sp-daten to code your cars modules (digital speedo etc etc etc)
      08-11-2014, 04:42 PM   #10
ferocity02
Drives: 2013 135is
Can not having the latest sp-daten files lead to connectivity issues? I'm trying to do the Alpina flash but WinKFP is saying it can't communicate with the ECU/controlunit when I try to program. I am able to read fault codes with INPA however.
I believe my daten is v49, which is what came with the coding pack you linked me to in my other thread.
      08-11-2014, 05:20 PM   #11
bmwmike
Drives: 2007 335i Coupe - SOLD
I'm seeding it for a couple hours now at up to 3 MB/s. Thanks for uploading it!
      08-11-2014, 05:37 PM   #12
danmcq
danmcq's Avatar
14
That is a definite possibility. Have you tried coding any modules with NCS Expert? If you are unable to do that, you should definitely try updating your DATEN files, and also verify that your system is configured correctly.
If you have never updated your DATEN files before, search around for 'BMW CODING TOOL.' It really simplifies the update process.
      08-11-2014, 05:39 PM   #13
ferocity02
Drives: 2013 135is
I have not tried coding yet, I need to find a decent guide to get me started.
I have never updated daten files, but I did see that it looks easy with the coding tool.
      08-11-2014, 05:48 PM   #14
danmcq
danmcq's Avatar
14
This is a good guide that I used to get started (and still refer to).
The Beginner’s Guide to Coding With NCS Expert
      08-11-2014, 08:46 PM   #15
MiniXP
MiniXP's Avatar
69
Original line:
LANGUAGE=DEUTSCH
LANGUAGE=ENGLISCH
I am in the process of downloading this (there's actually a decent amount of seeders right now).
The version I currently have has some stuff in English, but my errors I pull are in German. Will this help with that at all or do I need something else?
      08-11-2014, 09:58 PM   #16
ferocity02
Drives: 2013 135is
My service advisor said that they definitely updated the car when it was in there for service 3 weeks ago. Might that suggest that the v49 daten files will not work?
      08-11-2014, 10:02 PM   #17
danmcq
danmcq's Avatar
14
Very likely. The V49 DATEN files were released more than a year ago.
      08-11-2014, 10:24 PM   #18
chinko
Drives: 335i coupe
Thanks for sharing!
      08-12-2014, 10:25 AM   #19
2Cr4zy
Drives: BMW f30
Thx for sharing!
      08-13-2014, 11:04 PM   #20
spencers
Isle of Man
199
Drives: Sthrizzle
I've set up a mirror of the E89 part on Mega.
https://mega.co.nz/#!LsZjRISB!2rZXhG...jMeIOykcaYB7y4
      08-13-2014, 11:18 PM   #21
db2761
Drives: 08 335i
Thank you!
      08-14-2014, 05:31 AM   #22
Teq
Drives: E90
Thanks!
Tags
53.3, coding, e90, sp daten
