10-05-2022, 05:11 PM | #1 |
Rep 11
Comfort Access
2012 X5d
I’ve read a lot of the posts regarding this but my symptoms don’t really match anything I’ve read. Hopefully one of you can help. Symptoms: -All 4 door handles and trunk won’t unlock by touching the handles with the key in my pocket( I tried both keys) -steering wheel no longer moves up and back when I take the key out of the slot nor back into position when I unlock the doors. But the FOB buttons all work, the car will start with key in my pocket, no warm door handles, no battery drain/discharge issues. Fuse 132 is good. I had a local indie shop check for codes and they said no DTCs were stored. Also of note, the battery is from 50/17(Dec 2017 if I have that right) It seems when everyone else has a CA issue, it’s bc of a blown fuse or door handle failure which causes a high battery drain/discharge issue. Not sure what else to check. Not sure if this is related but I also had a parking break malfunction warning twice in the last month. I released the emergency release, no tension so it didn’t seem to be engaged. I then put the it in N and it began to roll so I knew it wasn’t engaged. Later that day, the warning was off. Thanks for the help. |
10-06-2022, 01:08 PM | #2 |
Rep 389
Drives: 2013 X5 3.5 Premium
Garage List 2018 Mercedes E400 ... [0.00]
2008 Porsche Cayman S [10.00] 2020 Chevrolet Subu ... [0.00] 2013 X5 Premium 3.5 [0.00] 2017 Nissan Titan SV [0.00] |
Okay so it's more than 5 years. Depending on how much you stress the battery it may be time to replace.
10-08-2022, 06:24 PM | #3 |
Rep 828
Maybe default code your CAS and maybe FRM (I say maybe because it's bloody temperamental) if the battery doesn't work, and it wouldn't harm to put a good battery into your fob if you haven't already done so.
10-10-2022, 04:48 PM | #4 |
Rep 11
The search continues. I went to get a new car battery but when they tested it the numbers were still good and they didn’t recommend replacing yet.
720 cold cranking amps 12.35-13 volts car off 13-14 volts w the engine on Charging rate 10 w car off Charging rate 15 w engine on Changed the battery in the FOB(just a watch battery) The passenger rear door now works to unlock and lock the car but the other 3 and trunk do not. @MrSweet, I just bought a foxwell, can I use that to default the CAS? Also should I keep the foxwell or get a diff set up? BimmerLink and code or bimmer geeks protool? Thx |
03-01-2024, 01:58 PM | #5 |
Rep 13
Drives: 2009 BMW X5
The ground battery clamp looks broken?
03-06-2024, 06:30 AM | #6 | |
Rep 82
Drives: Bmw e70 4.0d xdrive
