New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > E89 Z4 Classifieds > Commercial Z4 Classifieds
      11-10-2021, 03:38 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
Apex Sprint Line Forged Wheels for BMW E89 Z4 | Our Lightest Wheels
      11-10-2021, 03:39 PM   #2
Expert@ApexWheels
3525
Drives: M3
Your Fastest Lap is Calling!
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. For those looking to shed as much weight as possible to improve lap times.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Unmatched replacement program
➡︎ Lifetime structural warranty
➡︎ Independently tested and certified
Order Now
VS5-RS / EC-7RS / SM-10RS
Finishes
10K Tons Of Pressure
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
True Motorsport Blanks
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more about our true motorsport blanks.
Side-milled Spokes
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating. What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
Independently Tested
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
Laser-Engraved Specs
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1 year finish warranty. Exchanges are fast, easy, and hassle-free.
APEX Wheel Replacement Program
Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
A Fitment For You
We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
The Weight is Over
Specifications for our Sprint™ Line designs
APEX Forged Sprint Line Wheel Gallery
VS-5RS Gallery
EC-7RS Gallery
SM-10RS Gallery
Order Now
Questions?
Call: 925-245-0773
Email: expert@apexwheels.com
Web: www.apexwheels.com
Hours: M-F 9a-5p PST
EC-7RS Details
VS-5RS Details
SM-10RS Details
      11-11-2021, 05:24 PM   #3
Expert@ApexWheels
3525
Drives: M3
How APEX Engineers A Better Track Wheel
Crazy to think, but this is our first ever, in-depth video about any of our wheels.
Our engineering team put 2 years of hard work into our new Sprint Line and the forging dies that made them possible, so we were compelled to create a technical video that dives into the details. This video has a lot of great content our product descriptions don’t include. After watching, we’re confident you’ll truly appreciate why these features are so valuable.
If you're craving more content, this should quench your thirst.
      11-17-2021, 04:00 PM   #4
Expert@ApexWheels
3525
Drives: M3
Max Discount Unlocked! Save $400.00 off a set of Sprint™ Line Forged Wheels
Congrats everyone! We reached the 80+ people required to reach the Max discount in less than a week. Pledging is now a risk-free, no-brainer with a guaranteed discount of $400.00 a set and free shipping in the contiguous US.
There are still over 120+ people who are only signed up as interested, and they have not pledged yet. Only showing interest does not reserve any inventory or hold a spot for you in line, it just lets you follow along. Pledging is required to confirm your participation. And it’s risk-free – you can cancel your pledge any time before 12/31 if you change your mind. We highly recommend you pledge now, even if you’re on the fence.
      11-18-2021, 03:42 PM   #5
Expert@ApexWheels
3525
Drives: M3
We've added the full tables of incoming fitments and their specifications/ETAs to the OP. As you can see, this is a massive range of wheels that we will be bringing to market over a short time frame and this is only the beginning! Fitments that are not a part of the current ongoing Group Buy will have their own associated Group Buys prior to their arrival.
-Tom
      11-23-2021, 03:12 PM   #6
Expert@ApexWheels
3525
Drives: M3
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please fill out and submit our online form. All are welcome. Show us what you've got!
If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
      11-30-2021, 12:39 PM   #7
Expert@ApexWheels
3525
Drives: M3
Premium Finishes
Our New Sprint™ Line wheels are available in exclusive finishes right out of the gate. Brushed Clear gives a refined yet raw look that showcases our side milling and spoke profiles while fan-favorite Anthracite returns as a versatile option perfect for just about any color combination. Satin Black rounds out our finish lineup as the perfect understated option to provide contrast or complete a blacked-out look.
Which finish is your favorite?
Anthracite
Brushed Clear
Satin Black
Future Options
Beyond the custom forging blanks and weight optimization, our new forged production process is more flexible than ever. This allows us to include lower volume finishes and cater more to the needs of specific enthusiast markets that want a finish not yet included in our current lineup. Have a Satin Bronze or light Gold finish in mind? Something else we haven't even considered producing? Send us an email with the alternate finish you'd like to see become a reality along with your chassis and fitment details to experts@apexraceparts.com. Finishes with enough demand have a good chance of becoming a new standard option or being included in a limited run of wheels.
      12-03-2021, 05:25 PM   #8
Expert@ApexWheels
3525
Drives: M3
As we kick off the last four weeks of this Group Buy, we wanted to touch base to let you know that our first wave of production is right on schedule. This means we are currently on track to fulfill your orders in the timeframe outlined on the fitment table under the overview tab on GangUp. Things could always change, but everything is looking better than expected currently.
As a reminder, if you have only expressed interest and have not pledged, you're not officially a part of the deal to receive wheels. With nearly 400 members interested, some popular fitments and finishes will sell out in the first production run. We’ve already placed a restock order and it should be here pretty quickly, but we have not decided if we will cancel backorders or if we will allow late participants to get the discount and receive wheels from the second shipment. Be sure to come back and submit your pledge to lock in your order now to avoid the rush that always happens in the final week.
Technical Article
As a group of track enthusiasts and racers, we understand how frustrating it can be to bend a wheel in pursuit of a PB or podium finish. Whether you find yourself 4 wheels off track on a safari excursion or creating your own driving line jumping treacherous berms, wheels are put through a tremendous amount of stress and abuse in the process – sometimes simply being forged isn’t enough to avoid bends.
To mitigate this, our engineers made a concerted effort to reinforce the inner lip of these motorsport wheels and created our stronger, Sprint™ Spec inner lip design. If you haven’t already, we recommend you read our technical writeup on our Sprint™ Spec inner lip.
Blog: MEET THE STRONGER, APEX SPRINT™ SPEC INNER LIP
      12-07-2021, 06:31 PM   #9
Expert@ApexWheels
3525
Drives: M3
When Function Meets Form
As wheel specialists, we understand that when it comes to reducing weight and increasing stiffness in wheel spokes, there is a big difference between functional and aesthetic side milling. Instead of milling a few negligible millimeters of depth just to look cool, our engineers optimized our new motorsport blanks to create narrower yet significantly deeper spokes with deeper side milling that is nearly 50mm wide on some wheels. The result is a stiffer “I” beam-spoke shape that also showcases a stunning aesthetic. If you haven't already, we recommend you read our technical write-up on our deeper and wider side-milling.
      12-10-2021, 05:32 PM   #10
Expert@ApexWheels
3525
Drives: M3
With the release of our new forged Sprint Line wheels, we’ve had a few customers asking about how our upcoming EC-7RS visually compares to the classic forged EC-7R.
The overall design is obviously similar as this is our third iteration of the EC-7 design itself. Between the Classic Forged EC-7R and the new Sprint Line EC-7RS, the biggest visual difference will be seen in the spoke depth and side milling. Our new Sprint™ line of wheels features much deeper and wider side milling on the spokes versus our first generation of forged wheels. This improvement was made possible by our new motorsports blanks which allow us to create narrower yet significantly deeper spokes. The larger surface area on the side of each spoke allows us to take more material out. Doing so creates a much stiffer “I” beam or c-channel spoke shape. Visually that means the EC-7RS has deeper but thinner spokes with deeper side channels. The spokes of the EC-7RS also connect to the outer lip of the wheel, unlike our older EC-7R. This further reinforces the outer lip.
The inner lip won’t be easily seen when the wheels are mounted but has been updated with a unique C-channel as a result of a full redesign for additional strength in this crucial area. The inner barrel now includes laser etching to make specification identification a breeze and is a completely redesigned profile for even better brake clearance.
Porsche-spec etching shown
Ultimately, these changes were driven by our goal of improving our product offerings in a meaningful way. Beyond expanding the width and diameter offerings to fitments we’ve never before produced, these fundamental changes have resulted in higher performance wheels with an aesthetic that we are extremely excited about. 5x120 EC-7RS BMW fitments will be incoming with Group Buys of their own in the next few months. Stay tuned!
      12-15-2021, 02:45 PM   #11
Expert@ApexWheels
3525
Drives: M3
Get To Know Our 50% Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, or a club racer pushing the limit for a podium finish, mistakes happen, and parts can get damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our goal was to make replacing a damaged wheel with a brand-new one much more appealing than ignoring the problem or performing any questionable and compromising repairs. This program will also help keep damaged wheels from being passed on to unsuspecting enthusiasts via the secondhand market.
Discounted replacements are ideal for customers who accidentally damage their wheels with curb rash, bends or dings from potholes, berms, road debris, and off-track excursions. Complete destruction of a wheel from serious accidents also qualify, including tire wall or barrier impacts, contact with other racers, or any accidents resulting in a total loss.
All pledged members that participate in this Group Buy would be eligible for this replacement program. For more details, be sure to visit our website here.
      12-17-2021, 12:43 PM   #12
Expert@ApexWheels
3525
Drives: M3
What are Motorsport Blanks?
Join Yo and Eddy(APEX Founder) to learn how to spot wheels that may have been limited during the engineering phase to offer motorsport rich features and find out why we worked so hard to engineer new motorsport blanks to create our new fully forged Sprint Line wheels.
It was a long road to this launch, but now that we're here you all can look forward to benefiting from the features we can offer on the Sprint Line and future lines of forged wheels to come!
      12-21-2021, 04:27 PM   #13
Expert@ApexWheels
3525
Drives: M3
VS-5RS Profile Comparison
With so many new fitments available in our all new VS-5RS design, we’ve gotten a few requests to showcase the various profiles available. While all of our Sprint™ Line designs have their profile optimized on a per-application basis, we’ve categorized these wheels into 4 Profiles based on their depth for easy identification. Our investment in the Motorsport Blanks mentioned in the post above has allowed us to make Profile 4 wheels for the first time via additional material available to our engineers during the design phase of this project. These are the most concave wheels we’ve ever made and they help round out the Sprint™ Line which stretches from narrower high offset fitments for Porsche and non-M BMW chassis to wider low offset wheels for Domestic and widebody applications.
Profile 1:
Profile 2:
Profile 3:
Profile 4:
View the full list of inbound fitments and their specifications including Face Profile in the OP of this thread or on our website here:
VS-5RS
EC-7RS
      12-23-2021, 06:58 PM   #14
Expert@ApexWheels
3525
Drives: M3
It may not be a Z4, but we thought we’d share some photos and a video of this 1M on our new VS-5RS wheels. With a set of square 18x10 ET25 wheels and suspension architecture and other parts plucked straight from the E9X M3, we can’t imagine a better way to tear up the canyons.
Full Feature Thread
Technical article
All APEX Sprint Line forged wheels feature unpainted knurled beads. The problem with knurling is that it varies by manufacturer in design and effectiveness. Whether it’s a day at the track or months of street driving, repeated hard braking can make a tire slip on the bead seat and go out of balance, causing vibration.
Maintaining the effectiveness of our knurling was at the forefront of our minds when developing our new line of forged wheels, which is why there’s no paint covering the bead area. Instead of adding basic knurling with paint over it just to check that feature box from a marketing perspective, our engineers optimized the functionality of our knurled beads by leaving them unpainted to ensure they have a more effective “tooth” to bite into a tire’s bead. It is a more expensive process, but it is one of many details that results in a better wheel. To learn more, be sure to read our technical write-up below.
      12-29-2021, 06:20 PM   #15
Expert@ApexWheels
3525
Drives: M3
Our initial 18” Group Buy is drawing to a close
As the deal comes to a close and many people submit orders in the final hours, time is running out for our staff to respond to questions. We’re trying to get back to people after normal business hours to support pledges, but this year the deal happens to end on New Years eve. Our staff will likely be unable to answer questions that come in after 4pm pacific on Friday. If you’re on the fence and have questions, please submit them asap so we can get back to you before the deal ends.
Feel free to respond to this thread or email us at experts@apexraceparts.com.
      12-31-2021, 06:40 PM   #16
Expert@ApexWheels
3525
Drives: M3
As our initial 18" Group Buy Draws to a close, we thought we'd share some shots of a track-prepped e92 M3 on our VS-5RS wheels. Be sure to get your pledge in before the Group Buy ends.
Full Feature Thread
      01-05-2022, 06:38 PM   #17
Expert@ApexWheels
3525
Drives: M3
Our Initial Sprint Line Group Buy has closed. A huge thanks goes out to everyone that pledged and achieved the Max Discount. This was one of our most successful Group Buys to date and we can’t wait to see these wheels out in the wild. More Group Buys will be coming in the future with new fitments, diameters, and our EC-7RS design so look forward to those as well.
Technical Video
We prioritize brake clearance in all applications both for aftermarket and OE brake kits. Take a look at this brief video that dives into our data collection and development process used to make sure our wheels clear the most popular brakes of any kind.
      01-21-2022, 01:08 PM   #18
Expert@ApexWheels
3525
Drives: M3
With the first shipments of our Sprint™ Line wheels making their way into customers' hands, we’ve seen customer photos rolling in across social media. We love seeing these wheels in the wild and on your cars so keep them coming in!
Ashton (@ashtoncarlisle) sent in these images of his Satin Black 18x10 ET25 VS-5RS wheels wrapped in 275/35-18 NT01s mounted on his E90 M3 track car.
18x10 ET25 was an incredibly popular choice during our initial Group Buy with good reason. These wheels look right at home on this M3 and are a great front wheel option for the F8X M3/4s as well.
Though we focus on BMWs for these forum threads, we wanted to feature an APEX employee car as well. Our Market Research Manager Joe McGuigan (@joeMracing) picked up a set of our Mustang VS-5RS wheels in 18x10 ET40 wrapped with 275/35-18 Maxxis RC-1 R2 Tires for his Lexus ISF. The VS-5RS wheels are a great fit for these cars with centering rings and Joe put them to the test around Thunderhill East and West earlier this month.
When he's not parting the VTEC seas in Turn 14, Joe drives fitment testing and development for our new products and fitments here at APEX. He’s a massive Toyota fanboy at heart and even 2 additional doors and a bit of extra heft (from the car of course!) hasn’t slowed him down that much.
If you’d like to send us photos of your Sprint™ Line wheels, feel free to email them to Experts@apexraceparts.com. If you’d like to participate in a photoshoot or test fitment, submit an application on our new volunteer form.
Lastly, we know a ton of you are eagerly waiting for 19” Sprint™Line wheels. We recently received 19” sample wheels and photoshoots are underway to support our upcoming Group Buys. Here is a sneak peek:
Keep an eye on these threads and our Social Media channels and website for more information!
      01-26-2022, 06:21 PM   #19
Expert@ApexWheels
3525
Drives: M3
The first round of Sprint Line customer-submitted photos are rolling in and we're loving it! Check out @bcaing_’s F82 M4 on a set of staggered VS-5RS wheels in Anthracite finish.
Fitment Specs:
Front: 18x10” ET25 w/ 275/35-18 and a 5mm spacer
Rear: 18x11” ET44 w/ 295/35-18 and a 15mm spacer
Tires: Continental Extreme Contact Sport
We are still looking for more photoshoot volunteers for various BMW chassis. If you’d like to participate in a photoshoot or test fitment, submit an application on our new volunteer form.
We have another behind-the-scenes look at an APEX photoshoot for those of you curious about the process. This video documented an amazing build and photoshoot we did featuring the Magic Developed E46 Endurance race car on our Sprint Line VS-5RS wheels:
      02-01-2022, 06:50 PM   #20
Expert@ApexWheels
3525
Drives: M3
Our customer Greyson (@deity.46) sent in these shots of his new set of VS-5RS wheels on his F80. While staggered fitments are a common option for these cars, this 18x10 ET25 square setup looks undeniably fantastic on a set of Anthracite VS-5RS wheels.
Wheels: VS-5RS
Front & Rear: 18x10 ET25
Tires: Yokohama Advan APEX
Front & Rear: 275/40-18
      02-10-2022, 04:04 PM   #21
Expert@ApexWheels
3525
Drives: M3
We’ve loved seeing all of our M car customers on these VS-5RS wheels, but it's about time we showed some non-M chassis some love. Our Customer Liza (@htemup_b58) sent in these shots of her 440i F36 Gran coupe on an aggressive staggered set of our 18” VS-5RS wheels:
Wheels: Brushed Clear VS-5RS
Front: 18x9 ET30
Rear: 18x9.5 ET35
Tires:
Front: 255/40-18 Michelin PSS
Rear: 275/35-18 Hankook Z214 C5
This staggered setup is a great fit for her big turbo build and the wheels really look stunning on the 4 series platform.
Our 19” photoshoots are still underway to support the upcoming Group Buy. We can’t share the photos yet, but these wheels look great on the BMWs and other makes we’ve seen them on thus far and we’re excited to share them with you shortly. If you’re in the bay area and are interested in volunteering for an APEX photoshoot, our online form is still live!
Currently we plan on getting the 19” Group Buy live later this month with the first release of our EC-7RS design in the BMW market alongside the VS-5RS wheels. Stay tuned!
      02-24-2022, 04:31 PM   #22
Expert@ApexWheels
3525
Drives: M3
APEX | 19” Sprint™ Line Group Buy now Live!
Our 19” Group Buy is now live!
The Designs
For all of you who have been patiently waiting for our 19” Forged Sprint™ line wheels, the wait is over! We’re releasing a wide range of 19” BMW fitments for those of you running factory CCBs, 2NH M2 Competition brakes, or who just can’t get enough of that 19” look
VS-5RS
Our lightest wheel returns after its popular 18” debut on various BMW platforms. From clearing bigger brakes to mirroring popular OE widths and offsets, these 19s have an option for everyone.
EC-7RS
Our classic EC-7 design returns leaner than ever before. This is our first launch of the EC-7RS in BMW sizes catered to M chassis and aggressive fitments.
The Details
Fitments
Dates:
This deal is now live and locks on 4/5/2022 at 11:59 PM Pacific Time. The wheels are currently scheduled to ship out in May for all BMW fitments except 19x10 ET40 which should ship in June. Visit GangUp.com for more information.
Discount: Up to $500.00 off plus Free Shipping*
Join The Gang
To streamline pledging and fitment selection, we use GangUp to track interest and pledges. This system lets you commit at your preferred discount level and removes the old-school headache of forum threads and email chains as a Group Buy heats up. Watch the video below to learn how GangUp works and how to pledge.
These Group Buys depend on the BMW enthusiast community to succeed. More pledges mean deeper discounts and more competition for popular fitments and finishes. Make sure you pledge early to get the best possible allocation for your preferred set of Sprint Line 19” wheels.
More Info
VS5-RS / EC-7RS
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
*Free Shipping: This Group Buy offers free shipping to the 48 mainland US states. Buyers who have products shipped to Alaska, Hawaii, APO/FPO, and International destinations will receive a discounted shipping rate.
zpost
