04-10-2018, 10:23 AM | #1 |
Rep 709
What is that whirring / humming noise from under Glovebox?
I hear this almost every day, it randomly runs for a minute or two. Not very loud, much easier to hear when stopped at a light. Sounds like a fan or spinning motor, it spools up and goes for a short time, then spools back down and goes quiet. Not sure how else to describe it except for maybe a vacuum cleaner motor on 1/10 power.
What is it??
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
04-10-2018, 02:12 PM | #2 | |
Rep 551
Drives: 2018 M5 / 2011 X5 35d
04-10-2018, 03:33 PM | #3 |
Rep 709
Wow, you may be right. I never thought about that, I was fixated on automotive components being the cause. But that sound is similar. Still I'm not sure why it spins up randomly, but not often. Mine doesn't sound like locking, just smooth whirring. Wonder if the HDD has a fan for cooling...
I am going to give it a good listen on the way home!
heatmizr [Todd]
04-11-2018, 09:47 AM | #4 | |
Rep 189
04-11-2018, 12:42 PM | #5 | |
Rep 437
04-11-2018, 07:56 PM | #6 |
Rep 189
Just looked into it. Looks like CIC have very limited hardware spec.. probably not worth digging into it that hard.
04-12-2018, 07:35 AM | #7 | |
Rep 551
1. Faster boot times 2. Faster response time zooming in/out on the Nav and overall scrolling thru the menus 3. If you are IT savvy you can code it to add additional storage space for music 4. Technically speaking an SSD should be more reliable than a mechanical drive 5. You will end up with a back up assuming you keep the HD you took out of the CIC. |
04-12-2018, 12:56 PM | #8 |
Rep 959
Check if it comes and goes with your a/c being turned on and off. The blower fan for the a/c can get crap stuck it in or even get rusty or off balance. I've got the same thing in my m3 and my dads 5series.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
04-12-2018, 01:30 PM | #9 | |
Rep 189
04-12-2018, 01:43 PM | #10 | |
Rep 551
04-12-2018, 02:35 PM | #11 |
Rep 189
The only apple product I have is a macbook pro. Have it because I can make some seriously money by developing some iPhone apps, that's it. Everything else is pretty stupid and I dont know why people use apple product in 2018. Hack I dont even use any Microsoft product in my life because both of them and Google are greedy bastards.
04-12-2018, 10:25 PM | #12 |
Rep 872
+1 check blower, access from under glovebox
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
04-13-2018, 01:51 PM | #13 |
Rep 709
Thanks. I'm pretty sure the a/c has no correlation. It occurs sporadically under any/all/none a/c settings.
The last time it did it I wasn't doing anything with the iDrive console, it was just in the middle of a song that was playing, off the usb stick in the center console, so that shouldn't have needed to spin the HDD. It sounds louder and deeper than my pc hard drive, perhaps due to the placement of it enhancing the loudness/tone. Seems to be the logical assumption since we KNOW there IS a HDD in that space. Just doesn't sound 100% like it so I remain less than positive.
heatmizr [Todd]
04-13-2018, 01:58 PM | #14 | |
Rep 310
04-13-2018, 02:26 PM | #15 | |
Rep 551
04-16-2018, 12:20 AM | #16 |
Rep 288
It's not the hard drive, I have the SSD mod in my car and it still happens. It comes from the passenger footwell, and mine is super weird too. It comes on for 30 seconds to 1 minute and then goes away. Can't figure out what it is and it drives me crazy!!
Kaelan
1998 BMW 318ti w/ 35,000 original miles 2015 BMW X5 xDrive35i--2017 BMW X5 xDrive35d 2018 BMW X3 xDrive30i--2019 BMW X3 xDrive30i 1992 Mercedes G320D--2013 LR Range Rover Sport |
04-16-2018, 07:34 AM | #17 | |
Rep 551
I recently had my FRM module replaced/reprogrammed under recall so I have to assume that is working properly. One thing I'm almost positive about is that this noise isn't mechanical, so I assume one of the modules/CIC is making the noise. |
04-16-2018, 08:00 AM | #18 |
Rep 7,488
Has anyone considered the ebox fan?
The ebox fan is #13, #19 is the fan's bracket, and #21 is the air scoop (channel) in the diagram below: In pic below:
04-17-2018, 08:02 AM | #20 | |
Rep 7,488
https://www.newtis.info/tisv2/a/en/The ebox fan is different depending on which engine you have...the N63's & S63's ebox fan is #22 in the top diagram...you can find the part nbr for your specific BMW model by using any of the online part databases: Last edited by Qsilver7; 04-17-2018 at 08:21 AM.. |
04-25-2018, 01:28 PM | #21 |
Rep 709
Not sure what you mean about it not being "mechanical"; I feel certain it is a spinning motor/fan as I can hear it spin up and then down again to a stop.
EBOX Fan?? Any guess as to the purpose of said fan? I didn't see any stated on TIS. Or even exactly where to find it on the vehicle. If its to cool the area around the HDD, but the above poster with the SSD conversion did not remove it, perhaps it is still operating at times..? I can live with this infrequent hum noise, but would LOVE to know what its coming from.
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star Last edited by heatmizr; 04-25-2018 at 02:03 PM.. |
04-25-2018, 02:30 PM | #22 | |
Rep 551
Again that is what I hear on my car, since I cant hear what you hear in your case it may actually be something mechanical that you are hearing. |
