02-09-2015, 11:17 PM | #1 |
Rep 33
Lighting System Malfunction after Battery Change
I just changed the battery in my 2011 X5, and after resetting the date, time and X Drive (that was a malfunction too, but used the lock to lock trick and that went away), I am left with a lighting system malfunction. None of the interior lights work, the blinkers don't work, the angel eyes aren't on, and I can't switch off the headlights or taillights. Auto mode wont work either. Has anyone experienced this? I really want to avoid the stealership. This is a CPO car, but I am not sure this is something that would cover. Help
02-10-2015, 09:05 AM | #2 |
Rep 1,168
The FRM module is kaput. Some say you may be able to reset it, but most likely it will require replacement. If you're familiar with coding and have the tools, you can DIY.
02-10-2015, 03:46 PM | #5 |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
Oh boy, not another faulty FRM....
See if Okee can revive it for you (codemycar@gmail.com)
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
02-20-2015, 08:09 AM | #8 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I am in this boat right now. I hope the dealer can just flash the FRM module and be done with it. I can't imagine that changing a battery out would cause a module to short circuit and fry like that. If that is the case, it's piss poor engineering on the part of BMW.
I will be writing a nasty letter to BMW USA if I have to pay any fees above and beyond flashing the FRM module. A person should be able to change their own battery for crying out loud without having to worry about blowing out modules and the like. |
02-20-2015, 11:07 AM | #10 |
Rep 1,544
Why? I had to swap to the FRM3 to support the LED corona ring headlights I retrofitted. The part was $260 from Morristown BMW, and I programmed it myself. Why was yours so expensive?
02-20-2015, 01:31 PM | #11 |
Rep 66
They charged me 490.00 for the part... and then to program it. And 184.00 bucks to fix a leaking coolant sensor
12-22-2015, 01:01 PM | #12 | |
Rep 702
12-22-2015, 04:16 PM | #13 |
Rep 1,544
Tool32 and winkfp are your friends, learn to use it
12-25-2015, 06:17 PM | #14 |
Rep 137
Replaced my Electronic Junction Box the other day due to unstoppable rear wiper. Bought a used one for $100 and exact year from a 2007 4.8i too, so no coding needed everything work fine
2007 X5 4.8i Sports, Adaptive Drive, Rear Entertainment -In 2013 Nissan Juke Nismo AWD -In
2011 Mini Cooper S Countryman All4 -Out 2007 MB ML63 AMG- Out 2007 Acura MDX SH AWD Elite Package - Out 2008 Infiniti EX35 Journey iAWD - Out 2003 Nissan Murano SE AWD - Out2003 Infiniti FX35 AWD Tech Package- Out 2001 Subaru WRX - Out 1999 Subaru Forester S - Out 2003 Toyota Matrix XR AWD - Out |
01-09-2017, 10:14 AM | #15 | |
Rep 427
Did you get this problem fixed? I am having the exact same problem. Any feedback would be greatly appreciated. Thanks |
03-06-2017, 09:49 AM | #16 |
Rep 449
BMW has extended coverage on the FRM module, 10 year 120k, may want to call them and confirm, if you have symptoms of a fail module
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD 1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about 1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter |
03-06-2017, 11:54 AM | #17 |
Rep 1,340
03-06-2017, 02:46 PM | #18 |
Rep 994
Is there a proper replacement guide, to prevent a damaged FRM? It would seem like just the act of disconnecting the (-) lead and re-attaching could damage your FRM, as tempramental as these things are.
I am in need of changing my battery soon and will use mycarly to do the registration, but the last thing I need is a damaged FRM. My wife will be pissed.
03-06-2017, 03:06 PM | #19 | |
Rep 2,736
The dealers basically replace these like potato chips. They say they usually blow when updating the software. The act of disconnection of the battery probably shocks it somehow and causing the chip to fail as well. Touchy little bastards. Luckily their warrantied to 125k miles. |
03-06-2017, 04:36 PM | #20 | |
Rep 389
1. Go here: http://www.bmw-rp.com/production/isg...nsf/submit.xsp 2. Enter VIN 3. Pick "BMW EWL Footwell Module" 4. Go through process to get your money back. All of it. Had exact same failure after disconnecting battery (this also happens when clearing fault codes). FRM replaced and vehicle reprogrammed at no charge. A loaner was offered, too. |
03-07-2017, 09:09 AM | #21 | |
Rep 449
03-07-2017, 01:22 PM | #22 |
Rep 1,168
Just want to say thanks to folks who posted re reimbursement; even though the whole process took quite a while and involved few calls to BMW, got the $$ spent on fried FRM back.
