11-17-2014, 12:28 PM | #1 |
Rep 601
OEM X6 wheels on X5?
Hi everyone,
I would like to know if OEM X6 rims can fit on a X5 ? X6 OEM rims can or can't fit on a X5? or X5 OEM rims can or can't fit on a X6? or both cannot fit anyway Thanks for the help!
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD - 2008 E71 BMW X6 35i - Sport Pack = SOLD - 2007 E70 BMW X5 4.8i - Sport Pack = SOLD - 2007 E70 BMW X5 30si - Sport Pack = SOLD |
11-17-2014, 12:49 PM | #2 |
Rep 11,136
Front and rear E70 wheels have a 74.1mm center bore. E71 front wheels have a 74.1mm center bore also, but the rear wheels have a smaller (72.56mm) center bore. This means that you'd have to bore out the rear to 74.1mm, or buy adapters. This is the same for X5M wheels, by the way.
11-17-2014, 12:53 PM | #3 | |
Rep 601
So if I understand... X6 oem rims cannot fit directly on a X5. BUT, X5 oem rims can fit on a X6.
11-17-2014, 12:56 PM | #4 |
Rep 11,136
If I understand it correctly, the X6 rear wheels are not a direct fit for the X5. But X6 wheels will fit the X5, you just might have to rings to avoid have 1.54mm of play. The odd thing is that some wheels, such as the style 214s, were available on both the X5 and the X6. So I can only assume the 214s on an X6 would come with O-rings or something. Maybe someone else can chime in here?
11-17-2014, 01:44 PM | #5 |
Rep 467
X6, X6M, and X5M all have rear hubs that are 72.56mm.
X5 has 74.1mm hubs all 4 corners. So, front wheels are interchangable between all vehicles. Rear X5 wheels fit X6/Ms with a hub ring. Rear X6/Ms wheels fit X5 only if bored out or use a hub adapter as in pic. |
11-17-2014, 02:23 PM | #6 |
Rep 11,136
So did X6s come with hub rings from the factory since both the X5 and the X6 came factory with style 214s?
11-17-2014, 02:29 PM | #7 | |
Rep 467
I believe some offsets are different also for X6. I have X6M wheels Style 300 on for winter and I noticed the offset is 35 when all the X5M offsets are 37 I believe. Anyway, no rings for sure. |
11-17-2014, 02:30 PM | #8 | |
Rep 11,136
11-17-2014, 02:36 PM | #9 |
Rep 994
Hub centric rings are not a necessity. All weight is supported between the hub and wheel/hub face. The rings are for centering, but if the lugnuts are done properly, they will self-center as well.
That said, if you used a 74.1mm wheel, on a 72mm hub, just torque properly, rings are not required, just a nice to have. |
11-17-2014, 09:45 PM | #10 |
Rep 601
Nice! Thanks a lot guys!
I was looking for OEM X6 214 rims, but can't work on my X5. I'll wait to looking for style 214, 336 or 333.
11-18-2014, 04:54 AM | #11 | |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
11-18-2014, 07:30 AM | #12 | |
Rep 1,491
I have first hand experience with this! I got a set of 214 wheels from X6 and like everyone has mentioned the rears DO NOT fit due 2MM or so. The fronts have no issue. So I decided to have the rims bored out to 74.1mm, each wheel ran me about $65. After that they fit just fine and NO complaints. The boring out is the way to go if you find a good deal, again you have to add the cost and find a rim or machine shop. Good luck! |
12-04-2014, 06:46 PM | #13 | |
Rep 23
I did the same with my winter setup with no issues after the rims were bored out! |
12-04-2014, 07:31 PM | #14 |
Rep 137
I am going to pick up a set of X6 214 for my X5, will get them bore to fit.
2007 X5 4.8i Sports, Adaptive Drive, Rear Entertainment -In 2013 Nissan Juke Nismo AWD -In
2011 Mini Cooper S Countryman All4 -Out 2007 MB ML63 AMG- Out 2007 Acura MDX SH AWD Elite Package - Out 2008 Infiniti EX35 Journey iAWD - Out 2003 Nissan Murano SE AWD - Out2003 Infiniti FX35 AWD Tech Package- Out 2001 Subaru WRX - Out 1999 Subaru Forester S - Out 2003 Toyota Matrix XR AWD - Out |
12-05-2014, 10:50 AM | #15 | |
Rep 601
The X5 rims, you can put hub ring to rear wheels to fit on the X6, Or will you put adaptop on the rear hub?
12-05-2014, 01:10 PM | #16 |
Rep 137
Just get them bore the hub size a bit bigger to 74.1 it cost $65 a piece. Can someone confirm the actual correct size? 74 or 74.1??
12-05-2014, 11:42 PM | #17 | |
Rep 601
12-07-2014, 03:19 PM | #18 | |
Rep 994
And the hubs are actually critical to bearing weight. The lugs just secure it. |
12-07-2014, 07:43 PM | #19 |
Rep 601
I think the best, it's to get a set for X5 only..
02-02-2015, 09:55 PM | #20 |
Rep 601
Where can I get this adaptor to fit X6's rims on my X5 ?
08-01-2018, 12:07 PM | #21 |
Rep 120
Hi All,
trying to understand if I can use 19" V-spoke wheels, style 450 wheels from BMW X5 on my 2016 BMW X6 50i ( currently using original Style 594 19' ) both styles looks very similar but listed # 450 vs 594 Thx Mike
96 520i, 99 330i, 00 325i, 03 X5 3.0i, 06 X3 3.0i, 07 530i, 09 X5 4.8i, 10 M6 Conv, 11 X5 50i,
11 535xi, 14 X5 50i, 14 328xi GT, 16 X6 50i, 16 i8, 2019 X5 40i, 18 328d xi, 21 X5 40i, 22 X6 40i |
08-02-2018, 12:56 PM | #22 | |
Rep 7,485
Are you mixing wheels from different generation X5s & X6s (E70 to F16) or are you looking at wheels from the same generational cousin X5s & X6s (F15 to F16)? See the chart below for wheel specs...and you can also pull up the wheels in one of the online part databases to see if they have the same part nbr and are used on other BMW models. If you aren't familiar with any of the online part databases...see (and save) the sites below...they are invaluable in finding out the answers for questions like you've asked.
