      08-12-2016, 10:58 AM   #1
jonniex5
Drives: 2013 X5 35i
Wax on plastic trim
What do you use to get the white wax residue off the black plastic trim?
      08-12-2016, 12:33 PM   #2
-c-
-c-'s Avatar
Drives: bmw
They sell special remover for that, you can get it at autogeek.com , also I've heard you can use peanut butter but it's messy and I hate wasting food! .... .
      08-12-2016, 03:32 PM   #3
socale39
Drives: 04 545i SMG
I've used simple green diluted 50/50 and a brush. If it doesn't come off I make the solution a little stronger and go from there.
      08-12-2016, 10:59 PM   #4
Parise2713
Parise2713's Avatar
Drives: 2012 FBO E70 X5
Those might work ^
I'm a small scale mobile detailer. Deal with wax on plastics all too often.
I use an all purpose cleaner on mr. Clean Magic erasers. You can get those anywhere. Cvs, 7-11's, supermarkets ect...
For a cleaner a little dish soap would probably do the job. The erasers do most of the work. They have a little ammonia in them and the pad is just abrasive enough to scrub but not scratch. I'd give that a shot.
**Padny Detailing**
Padnydetailing.com
IG/ Facebook: Padnydetailing
      08-14-2016, 05:43 AM   #5
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
I just use maguiars quick detailer.
aspahn3.00
      08-15-2016, 06:45 AM   #6
jonniex5
Drives: 2013 X5 35i
Thank you all for the great suggestions,
I will start with the magic eraser as I have them already.
And will post the results.
      08-17-2016, 08:38 PM   #7
Peakrunner
Mile High Member
Drives: 2012 x5d
I have found this to be perfect for that job! http://store.jaxwax.com/Jax-Wax-Supe...-Oz-p/sb16.htm
I believe in Karma. That means I can do bad things to you all day long and assume you deserve it
      08-23-2016, 08:53 AM   #8
jonniex5
Drives: 2013 X5 35i
Peakrunner,
Thanks for the info, I just received the Jax Wax Super Blue, wiped it on with a sponge applicator and it removed it perfectly.
Also looks awesome on the plastic trim.
Fast and easy!
Thanks again
John
      10-21-2016, 11:49 PM   #9
Diesel X5
Diesel X5's Avatar
Drives: X5 35d X
I just tried this amazing stuff called Wurth Rubber Care and not only did it get the wax off but it also made the black plastic look like was new. The only down fall is it was $20.00 for a 10 oz can but "wurth" it. LoL
