01-06-2016, 12:56 PM | #1 |
1mGator
144
Rep 567
X5 35d engine code p0238
Hi everyone, I have searched and read numerous posts about various issues related to this Engine Trouble Code and would appreciate any direction from the community possible. Here is the problem:
Engine trouble light on with P0238 - Turbocharger / Supercharger Boost Sensor 'A' Circuit High Listed Possible Causes (according to engine-codes.com) - boost pressure sensor harness open or shorted - boost pressure sensor circuit poor electrical connection - faulty boost pressure sensor - faulty turbo/super charger - engine over temperature -ignition misfire exceeds calibrated threshold - faulty knock sensor (KS) What I have done so far ... Cleaned part# 13627792260 which is termed on realoem "fuel injection system - pressure sensor. I could not find "boost pressure sensor" terminology and other threads pointed to this item located on the driver side of intake manifold as a possible issue. When I took it out to clean it was clogged with carbon. I cleaned it with MAF sensor cleaner and reinstalled. I do not know how to test this sensor? How would I test to see if the carbon clog destroyed this one? Next I cleaned the MAF sensor on the cold air intake. If anyone can give me detail about how to eliminate the possible causes above one by one in a clear way I would greatly appreciate the advice. Currently, I clear the code and it goes away until we shut off and re-start the car and then it appears again. Thank you all in advance for any help! 1mGator |
01-06-2016, 06:19 PM | #2 |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
You need to change that sensor, I've had mine go bad and replaced it already.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
07-15-2017, 11:34 AM | #3 | |
Rep 22
Thank you |
08-03-2017, 05:15 AM | #5 |
Rep 22
Thank you 1mGator - l replaced the part about a week ago. So far error free! Thank you very much for the initial post. It sure helped my X5 run much smoother and it's so much more peaceful to drive w/o that pesky Check Engine light on. - thanks again
