BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Engine | Drivetrain | Exhaust
BPM
      02-14-2013, 01:19 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs. We are offering a limited time special for $95 per session, While some vendors are charging over $350 for similar services!
For a limited time, all Coding/Individualization options are on sale for $95/session! This includes popular options such as Video In Motion and Euro MDM!
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection. We love your M3 as much has you do!
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control units coding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your M3 is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Coding/Individualization (options may vary by model/build configuration) - $95, unlimited options
- Video In Motion (CIC iDrive models only)
- Euro MDM
- Remove BulbCheck errors (for HID/LED or aftermarket lighting retrofits)
- Windshield Wipers complete full cycle when ignition is shut off
- Remove Ignition/Door gong
- Remove iDrive [ACCEPT] screen
- Remove Seatbelt Warning Gong for Driver, Passenger or both Driver/Passenger (light will remain on dash)
- Unlock doors when key is ejected
- A/C off when Auto Climate is pressed
- Auto Sunroof close when rain is detected
- Open/Close windows with Key FOB
- Open/Close Windows with Comfort Access
- Open/Close Convertible Top with Key FOB
- AutoFolding Mirrors
- Change Low Fuel Warning from 1/4 tank to 1/8 tank
- Remove CityLights (Amber sidemarkers)
- Enable FogLamps with High Beams
- Disable Window Safety Feature (allows windows to continue rolling up while door is open)
- Enable Digital Speedometer in OLED gauge cluster
- Enable/Disable auto-correction for Digital Speedometer/MPG
- Euro SMG Software Updates for e46M3, e60M5, e63 M6 (~5000RPM Launch Control, improved shifting)
- Euro Hazard Lamps (double flash vs US single flash)
- Triple Blink turn signals
- Mirror Curb tilt
- Automatic Door Locking
- Auto Trunk/Tailgate Closing
... and much, much more.
Retrofit Options
- LCI Taillight Retrofits
- Park Distance Control (PDC) Retrofits
- Halogen Highs enabled with Xenon High Beams
- OEM Alarm Coding
- iDrive CCC-CIC Conversions/Upgrades
- LCI Headlight Retrofits
- FRM3 Module Upgrade/Coding
- Sirius Radio Retrofits
- IBOC HD Radio Coding
- Heads Up Display (HUD)
- CD CHanger, iPod/MP3, Dension & mObridge Coding
- Bluetooth
RaceCar/Track Preparation Setups
- Remove TPMS
- Race Seat Coding/Recaro Coding
- EDC Delete (for coilover setups)
- Airbag deletes for vehicles with roll cages
- Remove Headlamp Washer System
CBS Coding
- Flash Programming
- Dealer level ECU Software Coverage
- ECU Trial Substitution
- Quick Test & Quick Clear
- Fault codes timeline report
- CBS: Condition Based Service reset and error correction
- Retrofitting of BMW accessories and extras
- Car/Key Memory Function for personalizing vehicle
Service Options
- Module Troubleshooting
- Reset Adaptions
- Module value Monitoring
- Value Reporting (Fuel Pressure, Ignition Advance, etc)
BMW Dealer-Level Module Updates
- DME 240E and DCT Updates
- Individual Module Updates, including Engine ECU, TCU/ULF/mULF and iDrive
- MKIV, CCC & iDrive OS updates
and much, much more..............
Contact Details
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Address:
4015 E. Leaverton Court
Anaheim, CA 92807
Hours of Operations:
Mon - Fri: 9am to 5pm (PST)
Sat - Sun: Closed
Contact Info:
Phone: 866.669.0705
Email: info@europeanautosource.com
Website: http://www.europeanautosource.com
Available options vary among specific BMWs year, model and Vehicle Order (VO). Please feel free to contact me directly via phone, email or PM if you should have any questions and we will be happy to assist.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      02-14-2013, 11:49 PM   #2
rAdzM
Smashed!
Drives: 2009 E92 M3
2009 BMW M3  [10.00]
2006 BMW M5  [9.00]
why cant you be open on Saturdays?
est. 2008
BBS | BREMBO | RECARO | ig: @euro_rad
      02-15-2013, 12:13 AM   #3
Bimmr7
Drives: E92 M3 Comp/G80 M3 Comp on Ord
2013 BMW M3  [0.00]
2011 BMW 328  [0.00]
2010 BMW 335 M Sport  [0.00]
They are open on Presidents Day. That's when I plan on heading there.
      02-15-2013, 12:34 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
We are, already starting to get booked up!
Bimmr7: We'll see you on Monday.
      02-18-2013, 11:25 AM   #5
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Open on Presidents' Day!
Looks like we have a pretty busy Monday lined up
      02-19-2013, 04:18 AM   #6
tooshay
tooshay's Avatar
Drives: G20+M3 badge
So I can update my dme and cic along with any individualization for just $95?
G20 with some ///M3 stuff = G80
      02-19-2013, 11:59 AM   #7
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
You have PM.
      02-19-2013, 01:09 PM   #8
uplusd
uplusd's Avatar
Drives: 2013 E92 M3
Same question, does the price include updating my CCC along with personalization and retrofit coding?
      02-19-2013, 01:31 PM   #9
greenmoldy
Drives: 2011 e93 M3
How much would a DME and DCT update cost?
      02-19-2013, 02:07 PM   #10
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
What specific features are you looking to gain on CCC?
Module updates are different than coding, those that are on MOST ring that take considerable much more time (sometimes 3-4 hours), and possibly require other modules are updated as part of a group.
I see that you're in NorCal, will you be visiting SoCal anytime soon?
PM incoming!
      02-19-2013, 02:50 PM   #11
uplusd
uplusd's Avatar
Drives: 2013 E92 M3
I'm just looking to have the latest iDrive/CCC OS, as stated as an option in the first post.
      02-19-2013, 04:02 PM   #12
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
There would be no additional benefits to updating the CCC or features gained in doing so - I wouldn't recommend it.
However if you still want to update, let me know.
      02-19-2013, 04:49 PM   #13
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
240E DME update just completed (seen in Program Reference line):
      02-26-2013, 11:26 AM   #14
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Not something you see every day.
2011 E90 M3 in Estoril Blue getting coded with only 8000mi. Rumor is this was previously Frank Ocean's M3.
      03-02-2013, 03:23 AM   #15
m3less
m3less's Avatar
Drives: 15 AY M4
Thanks to Tom and all the guys at EAS! I had Tom code my Estoril E90 M3 and everything went smooth!
      03-02-2013, 02:49 PM   #16
esquire
esquire's Avatar
Drives: 2011 Dakar Yellow M3, 2018 M5
Just a quick endorsement from personal experience - EAS does superb coding work. They know what they're doing, and are super patient about getting you set up exactly the way you want. And the price is more than right.
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip]
[Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE]
      03-02-2013, 07:28 PM   #17
Sergm3
Drives: 2014 f10 m5 comp
Can you do coding on the 2013 550?
      03-03-2013, 05:13 AM   #18
M3Style
Drives: 2012 E92 M3
Tom, when does this deal end? can you PM me plz? thx.
      03-04-2013, 01:54 PM   #19
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
We're just going to keep it going on throughout March.
PM coming.
      04-22-2013, 12:21 PM   #20
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
X5M in for personalization/coding:
Specials still going strong!
      04-22-2013, 12:27 PM   #21
sales@ESSTuning
sales@ESSTuning's Avatar
390
Drives: ESS M3 / M4
I was in town for a quick visit and had Tom code a few things for me. If you need coding in the LA area this is the best place to go.
      04-22-2013, 12:36 PM   #22
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Originally Posted by Roman@ESS View Post
I was in town for a quick visit and had Tom code a few things for me. If you need coding in the LA area this is a great place to go.
Thanks, good catching up over the weekend. Here's a pic of your LRM3 getting coded:
Tags
240e, autologic, coding, eas, programming
m3post
