Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      08-21-2014, 03:32 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
▀▄ eas | DIY: Valentine One Radar Detector Hardwire
My V1 radar detector has never let me down. Its like a trusty co-pilot I've had for years, and usually one of the first things to do to a new daily.
I've never been a fan of the telephone cord visible on the windshield. While V1 has recently released the Savvy, it's just additional clutter in the cabin area and I'd probably end up taking it out with a wild kick by accident one day. Instead, we'll be hardwiring the V1 to turn on/off with the ignition.
Items Needed
- Valentine One Radar Detector
- Valentine One Hardwire Kit
- RJ11 Interface Cable
- (2) ScotchLock wire clips (not pictured, Red 18-22AWG)
- (2) Male Spade connectors (18-22AWG)
1. Start by crimping the spade connectors onto the hardwire kit.
2. Pull off trim plate on sunroof panel/light cluster.
3. With a small pocket screwdriver, press the retaining tab while slightly pulling on sunroof module and work out of place. There are (2) retaining tabs on opposite sides.
4. Remove plastic mirror housing by pulling apart. Crimp ScotchLocks onto wires as follows: Green/Brown Stripe & Brown/Black Stripe.
5. Route Power/Ground leads through headliner to exit by driver's side of rearview mirror.
6. Pull some slack on connecting leads by driver's side of rearview mirror.
7. Connect spade connectors to ScotchLocks as follows: Green/Brown = +12V Switched/KL30 & Brown/Black = Ground.
8. Connect RJ11 cable to [MAIN] port on V1 Hardwire Kit.
9. Reinstall mirror housing, route RJ11 cable through headliner to driver's side of mirror.
10. Reinstall remaining trim pieces and plug into RJ11 port on V1. Press START button and test.
Install is complete. Verify V1 position is clear of headliner and does not interfere with sun visor.
This and much more covered in our journal thread here: http://f80.bimmerpost.com/forums/sho....php?t=1020487.
Enjoy and safe driving out there!
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
Appreciate 8
      08-21-2014, 04:50 PM   #2
batchelorc
batchelorc's Avatar
Drives: Deez nuts
Great instructions. Thanks!
      08-21-2014, 06:29 PM   #3
Sir Loin
M3AT LOVER
Sir Loin's Avatar
Drives: Silverstone F80 M3
Excellent tutorial!
Your link at the end is broken with the '...' in the middle. This is the correct link:
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
      08-21-2014, 06:34 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Originally Posted by Sir Loin View Post
Excellent tutorial!
Post edited with non-truncated link, thanks for the heads up.
      08-22-2014, 09:02 AM   #5
Pleather
Drives: 2015 M4
I've been waiting for someone to post this....much thanks. Question though. Did you access the wires under the light dome or did you also remove the housing around the mirror? When I jumped into this last night, I could only find those wires in the small harness leading to the mirror. Unfortunately I'm still not getting power...???
      08-22-2014, 11:17 AM   #6
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Either works. It's easier to tap into the wiring behind the mirror clamshell since they are not wrapped up in tape and route back underneath the interior light housing.
Double-check your connections with a digital multimeter, also make sure the spade connector blade inserts into the slot (and doesn't push) aside when inserting into the scotchlock, not making contact.
      08-23-2014, 10:40 PM   #7
tooch
Drives: F82
this is what Ill be doing once I can find the crimp piece of the set up. that goes on the wire I had to leave those on my e92. Anyone know where to buy these? Any pep boys ? Thanks
96 E31 JB
07 E92 AW
F82 BSM
      08-25-2014, 07:25 AM   #8
celler
celler's Avatar
14
Drives: F80 M3
Thank you for the detailed instructions. I see that you did not opt for the concealed display. Has anyone run the wiring for that? Any preferred place? I'm trying to find a spot on the instrument cluster where I won't block information. I suppose I could use the Android app for the display for that although I do not know if using the Android app turns off the display on the V1 the way the concealed display does. Plus, the Android phone is busy running Waze which is a wonderful app.
      08-25-2014, 02:44 PM   #9
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Scotchlocks can be found at any radio shack or 12V installation shop.
The cable can be run down the A-pillar if you want, just make sure not to get in way of the airbag.
      08-25-2014, 02:55 PM   #10
celler
celler's Avatar
14
Drives: F80 M3
I'm not sure how to do that without removing the A-pillar. I've always just carefully stuffed wires behind it, but that was before side airbags.
      09-30-2014, 09:42 PM   #11
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Had a couple of V1 wiring inquires, bumping to the top of the list.
      10-06-2014, 12:44 PM   #12
M427
M427's Avatar
Drives: 2015 M4, 2019 X7, 2004 R1200C
Great idea with the scotchlock wire clips and tapping behind the mirror. I set out to install my V1 Hardwire Kit this weekend, only to be tripped up on the "ground the black wire" step. There is absolutely no metal to be found under that carbon fiber roof! Now,off to Radio Shack...
      10-09-2014, 05:09 PM   #13
Sivart321
Sivart321's Avatar
32
Drives: 2015 F80 M3
Do you know if there are any non-switched 12v sources in that same location?
      10-09-2014, 05:51 PM   #14
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Not aware of any that do not go into sleep mode in that particular location, sorry.
      11-30-2014, 06:13 PM   #15
JDUni1
JDUni1's Avatar
Drives: '15 M3, '12 135i (Sold)
My V1 has never let me down. Its like a trusty co-pilot I've had for years, and usually one of the first things to do to a new daily.
Items Needed
Tom, where did you stash the interface module that wired the RJ11 cord to the V1 as shown in this pic? Do you have a better pic of where you attached this?
2015 Alpine White ///M3 | Sakhir Orange/Black Extended Merino Leather | 6MT | Lighting Package | Harmon Kardon | H&R Sport Springs (F32) | iND Cosmetic Treatment | M Performance Spoiler | 19" HRE 301M Frozen Red| Mode Carbon Trophy R1 Diffuser
      12-01-2014, 11:37 AM   #16
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
There's a small space above the driver's side visor everything can tuck into. Wouldn't hurt to add some insulation to keep the splitter from rattling around.
      12-01-2014, 06:40 PM   #17
JDUni1
JDUni1's Avatar
Thanks!
      03-15-2015, 07:49 PM   #18
GBGASTOWERS
Drives: 2015 M4 CONV MT,YMB,SS
I wasn't getting power either. Turns out the wires I was tapping into by the mirror were so small I had to pinch the metal a bit closer for the scotchlock to actually make contact with the wire I was tapping. Fixed the no power problem and now have a clean install.
      03-15-2015, 07:55 PM   #19
GBGASTOWERS
By the way I did it on my M4 conv so the dome light housing is different. It has 4 metal clips that hold it in (2 front. 2 backside) Plus you have to remove a trim bezel first. I just pulled the rain sensor/mirror windshield trim apart grasping it from the top.
      03-16-2015, 09:02 AM   #20
PDACPA
Drives: F33 M Sport 435i
Can you post a pic of your install in your M4 convertible? I have a 435 Convertible and thinking of hardwiring my V-1.
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk
      03-31-2015, 07:32 PM   #21
DaBean
Sakhir Smurf
314
Drives: Plaid, F82 M4, E46 M3, Sequoia
2002 BMW X5 4.4i  [0.00]
2015 BMW M4  [0.00]
2004 BMW M3  [0.00]
Thanks for the writeup.
Two questions / requests for confirmation:
1) Does this work well without the sunroof? Any risk of "burning" the wires as the V1 will draw more current than they were designed for?
2) Does the V1 turn on/off as the start/stop function is enabled?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads
NASA NorCal Instructor
      03-31-2015, 08:09 PM   #22
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
We have the V1 installed on our carbon-roof equipped M4, this is a switched +12V line, so it will turn on/off properly with the ignition.
No issues with Start/Stop.
Tags
eas, hardwire, radar, valentine
f80post
