07-23-2014, 01:57 PM | #1 |
BimmerPost Supporting Vendor
8113
Rep 18,808
▀▄ eas | DIY: S55 M3/M4 BMC Filter Installation
A panel air filter is commonly referred to as a replacement air filter. It is installed in the vehicle's original airbox to replace the OEM air filter. It is made of high performance materials that allow for an increase in air flow along with more efficient filtration. These BMC filters guarantee containment of all impurities from as small as 7 microns, as compared to the OEM's 10 microns.
BMC air filters are produced using a full molding system that enables the characteristic red filter to be realized from a single mold with no welded joints, thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes. BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity. All BMC air filters are pre-oiled, and they can be washed and regenerated by using an appropriate regeneration kit. Installation BMC High Performance Replacement Air Filter (set of 2) https://europeanautosource.com/bmc-h...r-filters.html Tools needed T25 Torx driver Pocket screwdriver 10mm & 13mm Wrench (socket) Trim Removal Tool Installation 1. Remove compression rivet from trim cover 2. Remove plastic nuts from right bank cowl cover, note these are twist-lock design (90-degree twist) 3. Remove compression rivet from trim cover 4. Remove plastic nuts from left bank cowl cover, note these are twist-lock design (90-degree twist) 5. Remove compression rivet from strut tower brace trim cover 6. Remove Bolts securing strut tower brace (13mm), nut on coolant reservoir is 10mm. 7. Carefully remove strut tower brace and admire BMW's craftsmanship. 8. Remove bolts on right airbox with T25 torx driver to reveal filter 9. Remove filter lid 10. Remove charcoal liner with small pocket screwdriver to release tabs 11. Drop new BMC oiled filter in place. filter comes pre-oiled from factory. Reinstall filter lid 12. Pinch plastic securing mount and lift on right filter housing to move out of place 13. Pinch/remove PCV hose and remove. Remember to reinstall after filter is installed. 14. Remove bolts on left airbox with T25 torx driver to reveal filter 15. Remove filter lid 16. Remove filter lid 17. Reinstall left filter lid Torque Specs Airbox: Snug to fit/hand tighten Strut tower brace 13mm: 10-12lb-ft. 10mm: 3-5lb-ft Enjoy! Feel free to respond to the thread with any questions.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 01-30-2018 at 10:59 PM.. |
9
07-24-2014, 11:12 AM | #2 | |||
8113
Rep 18,808
These will be most beneficial once mods (exhaust, tunes) start appearing, along with being reusable. The pictures make it a bit more involved than what it really is, but we wanted to make sure all steps were covered. It's simply remove the strut tower brace and install the filters.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Kooch102.00 |
07-24-2014, 11:20 AM | #4 | |
Rep 3,249
I believe it. There usually isn't any significant gain, but had to ask. I guarantee the intake and spool sound is more prominent now as well.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
07-24-2014, 11:23 AM | #5 |
8113
Rep 18,808
Most dealers wouldn't even care. You can keep the charcoal liners, but we would recommend removing them for better airflow.
D_SheerDrivingPleasure1089.50 |
07-25-2014, 06:56 PM | #7 |
8113
Rep 18,808
Corrected.
08-03-2014, 02:26 AM | #9 |
Rep 3,151
Nice DIY. Thanks EAS
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
08-11-2014, 02:58 PM | #10 |
Rep 1,238
Drives: 2020 X6M Competition DG
thanks for the write up!
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
08-22-2014, 05:26 PM | #12 |
Rep 690
i would take them out if you blow your motor, just in case. other wise there really wont be a time where they look at your filter. unless you are having a engine related problem. even at that point, i think they would let it slide also. haha
09-20-2014, 10:37 AM | #14 |
Rep 130
Drives: 2015 Austin Yellow M4
Easier to find, in the middle of it right now
10-13-2014, 09:13 PM | #15 |
definitivecars.com
354
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
Did this, thanks for the DIY. Of course even though I organized the screws and bolts on the workbench and counted as I removed them, I somehow still had once less compression rivet as I started with.
Over all pretty easy. D |
12-11-2014, 07:25 PM | #16 | |
Sunburnt Member
158
Rep 525
Did you remove the charcoal filters?
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
01-02-2015, 03:43 PM | #17 | |
Mr. Fluffy
35
Rep 274
The intake doesn't have more growl it has more spool sound though. It's not OMG cone filter spool sound, but it's more pronounced than stock for sure. Doing 3rd/4th gear pulls from down low are fun to hear now especially with the anti-lag |
02-19-2015, 10:09 AM | #18 |
_______
169
Rep 1,088
Installed today. Thanks for the write-up. Very simple.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
03-06-2015, 01:35 PM | #19 |
Rep 2,171
03-06-2015, 01:37 PM | #20 |
_______
169
Rep 1,088
The spooling is noticeable. It's a cool sound. Not sure what brought out the noise more, the filters or removal of the charcoal filters, but either way it's a good noise. Not obnoxious, but if you like to hear your car doing stuff, this is worth it.
03-08-2015, 04:20 PM | #21 | |
Mr. Fluffy
35
Rep 274
There was a sale for the k&ns for $56 on another thread. |
03-20-2015, 03:11 PM | #22 |
Rep 706
No need for step 5 here,
Managed to pull it through the gap. The other side trim covering the brace is able to lift up which gives you leeway to pull it through the gap. Great right up and really helped me |
Tags |
bmc, charcoal, eas, filter, intake |
