05-04-2020, 11:51 AM | #1 |
California Diesel Guy
Rep 70
6AT Torque Limits???
Does anybody have experience with transmission damage in their 35d? It seems that the official torque limit of the 6HP26 is 443 Lb/Ft, and most tunes would bring the trans past that limit. Does it require a tune or a complete rebuild to stay reliable? I'm not very experienced with transmissions, so any help is appreciated.
Previous Affairs: 2011 335i Msport, 2007 Honda Pilot:, 1991 316i R.I.P
05-04-2020, 01:10 PM | #2 |
i'm just saying
5766
Rep 2,634
it has different stages that can handle different torque figures like all transmissions..
and they all need disassembling for swapping for better seals and parts.. besides transmission lifespan is highly connected how you treat it though as you know.. assuming no faulty parts.. you can break a transmission by pulling on bad surfaces or putting too much load on it with the same power.. im used to nm not lbft but im guessing it should be around 600-650nm as you mentioned.. basically vibrations and another overlooked fact kills transmissions.. its the heat.. old fluids or below min level fluid can kill a transmission so fast.. seen many times with tuned cars, well maintained transmissions can handle more powers.. long story short for your question, yes it needs to be rebuilt..
05-04-2020, 08:32 PM | #3 |
Rep 714
Lots of us are deleted and tuned. 335d's and x5d's dyno on stock turbos with just deletes and tunes up to 550 ftlbs and you'll see people do that reliably for 100k+. As long as you're willing to change the fluid, filters, and some seals (not upgrade, just normal maintenance) the trans should last the life of the vehicle, even tuned.
There are people on hybrid turbos that push the limits and most all of them run stock trans. I'm not saying they'll last forever but this ZF6hp is a STOUT. trans. Mine's at 257k miles, and it's been deleted and tuned for 45k miles. Ive also towed about 7k of those miles, maybe more than 7k at this point. And I'm not nice to it when towing, I kind of rip on the thing. Still fine, no real slipping, but the 4-5 shift misses if I'm absolutely full tilt and don't lift at all during it while towing. But even that fault, no one but me would EVER notice that single particular fault in my beat on 256k mile transmission. As far as I know, I was the first person to ever service it, and that was at 230k miles. |
05-05-2020, 09:15 AM | #4 | |
Rep 1,057
All about how you treat it and maintain it.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
05-05-2020, 11:13 AM | #5 | |
Rep 714
But then again, if I need more power it's really because I'm towing more, and if I'm towing more it's probably time to just buy a real truck lol. |
05-05-2020, 01:43 PM | #6 | |
Rep 1,057
For our x5ds though we have the option to upgrade to the r90 pump. R90 will keep up everywhere, especially down low in rpm. One of the dyno threads showed an 80lb-ft increase in r70 vs r90 pump with same malone 2.9 tune. My x5d will be getting this pump. Definitely a worthwhile upgrade for the torque increase and to be able to keep steady rail pressure. R90 with hybrid Lp tims turbo upgrade should support 450+ hp and 700+ lb-ft though, which for $325 for r90 and around $1,600 for tims stage 3 lp turbo you're still less money than dual pumps at $325 for r90 and $2,300 for dual pump kits and you get similar power levels. Also, no need to upgrade injectors. Our stock injectors can keep up. I want to say they were good for something like 700hp, which is crazy. Who needs a truck when you have an x5d with 700lb-ft
06-03-2020, 07:52 AM | #7 | |
Rep 714
Thing is, my trans won't hold any more power in it's current state. My next big upgrade, after the new diffs/ new suspension, is going to be a trans rebuild or replacement along with sutphin's converter. I feel like I'd rather spend money at first on the converter before an LP turbo. The stock converter definitely leaves power on the table. Eventually, once I trust my trans, and have the upgraded converter, Id love to go for an LP. When towing, I'm usually not full throttle. Trans doesn't really like it. Usually doesn't slip, but sometimes it does a tiny bit. Most of my towing is HP turbo spoolin. |
06-03-2020, 10:16 AM | #8 | |
Rep 1,057
What suspension did you go with? Is your trans tuned btw? I can't remember if I've asked you before I can imagine the x5d doesn't like the LP spooling while towing but I'm wondering if it's your trans tuning. Which in my experience stock tuning translated to a sloppy shift while under load. What mode do you drive in while towing? D, DS, M mode? If you do go with rebuilt trans with upgraded converter and tune you'll likely get better results. I'm sure your trans is tired!
06-06-2020, 04:11 PM | #9 | |
Rep 714
Mine is like, 80% of the time totally fine with spooling the LP while towing, but she hazes a bit from the extreme load. Trans isn't thrilled, but depending on the situation it's totally fine with it. I'm tuned with sutphin's. I usually end up doing manual mode around city/town/ state roads, and if I'm using cruise control not he highway I'll put it in 6th. It'll hold 6th and roll into the boost in cruise, but it eagerly downshifts when in D sometimes. So on the highway for long distance I let it do load up gears on cruise control and if it starts losing steam it'll downshift. Around town I prefer M mode just to short shift it a bit, but if I leave it in D is really does do a fine job. When I towed for 2400 miles straight it definitely learned from it, and towed really nicely in D by the end of that trip. If I go for a rebuilt trans I'm so tempted to do the whole package. Rebuild with upgraded clutches, sutphin's valve body, the converter, and I'll have a future proof transmission for the rest of my time with it. Realistically, if I ever get a new truck, I'll still have this and it'll become my girlfriend's daily driver. I'll still have the ability to use it to tow when needed if the bigger rig isn't necessary, and it makes a heck of a long haul vehicle. Especially after the future diff swap, it'll be a 32+ mpg long hauler with family capability. |
06-06-2020, 07:18 PM | #10 | |
Rep 1,057
Ah okay probably just a tired trans like you say. That trans should be stout enough to tow no problem. That's pretty impressive that it learns like that while towing though! My thought process on my x5d trans tuning is d-mode will be gf mode lol, ds-mode will be a tow haul mode, then m-mode configured for me. I don't think I've heard anyone with an x5d with a trans rebuild. If you do go with it I'd love to hear your opinion on it! Should be the ultimate family hauler! I know my gf ask all the time to use my x5d and my 335d I'm just like don't you have your own brand new car lol. Shows you how nice these cars still drive for their age though
Tags |
transmission |
