11-11-2019, 08:17 PM | #1 |
Rep 557
2012 5.0 with 50k - quart of oil every 500 miles!
Is this normal? I've owned the car since new, and its been meticulously cared for, serviced only at the dealership, all the recall work has been performed.
My daughter has been driving the car for a few years, and as of late she's having to add a quart every 500 miles or so. I know these engines are notorious for burning oil, but this seems excessive. |
11-11-2019, 08:37 PM | #2 | |
Rep 1,564
Three main Culprits here in order of what you should replace first: CCV Tubes, Your Valve guide seals, and your Turbo Oil return lines. Ask your service rep to perform the oil burn test, I believe with your low of miles they will cover all the repairs under BMW extended warranty (not 100% sure on that so dont quote me but worth looking into ). If for some reason they wont, follow the directions below: Start off with replacing all of your Crank Case Ventilation lines. If still excessive oil burning then next up is having your valve guide seals replaced. Parts are cheap (less then 200, Labor will kill you, around 3000+). Turbo oil return lines can get blocked too in these engines, however this normally burns even more oil at a quart every 100 miles or so but I recommend having them replaced also when doing the valve guide seals since everything will be torn down anyway. |
11-11-2019, 09:09 PM | #4 | |
Rep 3,658
11-12-2019, 09:54 AM | #6 | |
Rep 3,658
https://www.topspeed.com/cars/car-ne...-ar166918.html |
11-14-2019, 01:36 PM | #7 |
Rep 709
Surely you must have seen the multiple threads on here about the infamous Valve Guide Seals?
Give your Service Advisor re: valve stem seals lawsuit. I didn't need ANY of my lawsuit papers I got in the mail; they are doing so many of these I think they decided to just check for the telltale smoke, and schedule the work. For reference... My V8 had 58k miles and I was adding about a qt every 800 miles. I did the self-test - let it idle ~3 mins and then floor it and look for the smoke in the exhaust - and it was smokey alright. I had them look at it in July, they agreed it needed the job, and did the work in one week. No paperwork, no hassle. No issues since, and no oil added since either. This work was FREE of Charge. Good luck!
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
11-14-2019, 09:45 PM | #8 | |
Rep 557
11-14-2019, 09:46 PM | #9 | |
Rep 557
Floor it in neutral, or have someone drive it while you observe? With that being said, do you trust the dealer with such an invasive procedure? If they mess something else in the process, maybe its just easier to keep adding oil? Last edited by och; 11-14-2019 at 10:04 PM.. |
11-15-2019, 08:05 AM | #10 | |
Rep 491
I don't want to mess up a perfectly running factory installed engine |
12-03-2019, 04:56 PM | #11 |
Rep 66
my 2011 50i was burning 1q / 500miles, i got engine replaced under the Bang vs. BMW Class Action at BMW Brooklyn. I paid 15%( i had 60k miles) of the cost which was ~$1,900.
I had to wait 5 months for the replacement engine. |
12-05-2019, 01:20 PM | #13 |
Rep 4,060
There should be a class action on the 2012 X5 transfer case issues as well.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
12-05-2019, 02:32 PM | #14 | |
Rep 557
If I do go ahead with the engine replacement under the warranty, my car will effectively cost more in warranty repairs than what I paid for it. |
12-11-2019, 03:55 PM | #15 |
Rep 557
The car threw a CEL today, that went away after restarting, and there is a strong sulfur smell out of the exhaust when it idles. The spark plugs were replaced fairly recent, and it had the injectors recall.
12-21-2019, 06:55 AM | #17 | |
Rep 491
Its at 115k miles. I am the third owner still it was approved for valve seals replacement at NO cost to me. My Service Adviser is a nice young chap. He told me they can do a lot of OTHER stuff at very cheap labor rates as the engine is pulled down for the Valve seals. So I am taking advantage of the cheaper labor and replacing all the suspension control arms and ball joints . Also replacing Aux water pump and Thermostats. Also replacing all the turbo return lines and coolant hoses. Replacing coolant reservoir and power steering reservoir. Plus I get a brand new 2020 X5 as a loaner for two weeks . WIN WIN Last edited by X5 MAN; 12-21-2019 at 07:58 AM.. |
12-21-2019, 10:22 AM | #18 | |
Rep 1,564
For example, the drivers side CCV tube will cost you about 400-500 dollars to have replaced by the dealer without the engine out. With it out it should only cost you the price of the part (80.00)and maybe 10min of labor as you can litteraly replace it in a few minutes. Same with the turbo cooling lines. Have them replace all your vaccum lines and possibly water pump too and have been replace the turbo auxiliary water pump (under recall) while they are in there. You will save thousands doing it now and make the engine worry free for years. Don't forget to ask for the "N63" discount on the parts. Seriously, most dealers will knock 10-30 percent off the cost of parts if you just ask. |
12-27-2019, 12:31 AM | #21 |
Rep 557
The dealer is working on the car. The CEL was due to Vanos solenoid, they are replacing it with just the cost of the part, no labor since its taken apart.
They quoted me $1600 to replace coolant return lines while they are at it. Expensive but I approved it. |
12-27-2019, 01:54 PM | #22 | ||||
Rep 29
Any suggestions for me going into the dealer for service with this car? I am looking into the battery service recall and maybe the valve seals if available to me. Quote:
Could you give an idea to the cost for all of the extra work you are getting done with the valve seal job? Thanks - PG Last edited by Steepcreeker; 12-27-2019 at 02:05 PM.. |
