      04-17-2017, 05:08 PM   #1
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Question on offset/ lug nuts
hey folks - I swapped the X5 d wheels from standard 18s to Rohanas 20s : Specs are:
20x10 ET33
20x11 ET25
Question is, rears lug nuts have broken twice, they get 5 threads into the hub (I heard there should be 8 full turns into the hub) - If I were to get extended lug nuts how long should I get ? Tire shops have no idea
also, I think standard bolts are: M14 1.5 I could be wrong...
thanks for the help
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      04-17-2017, 07:42 PM   #2
Googone20
Googone20's Avatar
176
Drives: 2015 X5, 2007 M6
Do yourself a favor. Buy a set of nice wheel studs from Ryan Castro from Motorsports Hardware. I have run his kits on several of my cars, and never had one issue. I already installed a set of 83mm studs with silver lugs on my X5. They are stronger and safer than wheel lugs, and you can order whatever lengths you want, which will allow you to run different spacers without having to change lugs all the time.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa
2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa
2007 BMW M6 Sapphire Black Metallic/Black
2005 Ninja 636 Lime Green
