      04-17-2017, 07:49 AM   #1
rithvikrao
Drives: 2013 BMW X5 5.0 M-Package
2013 X5 5.0i M Sport Brakes
Hey , if the brake light is on for the front brakes, do i just need to replace the pads or does the sensor need to be replaced with them. Just wondering what I need to order besides the pads to get this fixed.
      04-17-2017, 09:34 AM   #2
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
I'd replace the pads and sensor for sure, and rotors too based on when they were replaced last.
      04-17-2017, 12:25 PM   #3
rithvikrao
I'm gonna replace the pads , front and rear, and the sensors in the front. Wait till it wears and then replace all of the rotors and pads with performance items. I think thats the best way to go at the moment.
      04-17-2017, 09:58 PM   #4
socale39
Drives: 04 545i SMG
If those rotors have already been through two sets of pads it's time to replace.
      04-18-2017, 09:01 AM   #5
rithvikrao
I actually dont know if it has , I got the car with 29k , and its now at 50k and i need new pads, so this might be the first set ?
      04-18-2017, 03:17 PM   #6
socale39
Drives: 04 545i SMG
Does the outer edge of the rotor have a noticeable lip?
      04-21-2017, 02:44 PM   #7
Ryan5034
Drives: 2019 X5 50i
You need to at least have those rotors resurfaced at an autopart store. If not you will lose a lot of braking power because the rotor to brake pad surface will not be even. You don't have to buy new rotors but the auto part store should be able to cut them and tell you if you are in spec.
      04-23-2017, 06:09 PM   #8
rithvikrao
decided to replace the rotors and the pads and all of it , any suggestions?
      04-23-2017, 06:13 PM   #9
socale39
Drives: 04 545i SMG
Brembo Zinc plated rotors and Textar ePad or Akebono. Those would be my choices.
      04-23-2017, 07:46 PM   #10
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
Zimmerman rotors with textar/pagid pads.
      04-23-2017, 07:47 PM   #11
socale39
Drives: 04 545i SMG
If brake dust is an issue for you but you like the OEM pad feel and initial bite, the Textar ePad offers exactly that. It's the new compound they are using for all the newer models.
One thing I forgot to mention is to avoid cross drilled or slotted. No real gain, chew through pads and traditionally are louder when braking.
