      04-13-2017, 10:35 AM   #1
WULFFZA
WULFFZA's Avatar
Drives: 2011 335i MSport / 2012 X5 35d
Wanted: A smoother ride - replacement shock/spring suggestion?
Most suspension posts relate to lowering and improving handling.
I have a 2012 X5d sport package with style 214 20s on regular tires with standard suspension and self-leveling rear. The ride is terrible, bounces and rocks at the slightest undulation or imperfection in the road.
I find it exhausting and unsettling to drive due to poor road surfaces we have on my daily commute, but since I still have warranty left and mileage is quite low I am not ready to get rid of it yet.
Yeah, I'm getting old, I want a smoother ride and don't carve corners the way I used to.
Suggestions?
Also considered finding a used set of the stock 19inch wheel and tire setup, non runflat - not sure that will make enough of a difference?
2011 E90 335i M-Sport 6MT Alpine white - saddle brown
2012 E70 X5 35d Sport Activity - Alpine white - black
2005 Toyota 4Runner 4WD Sport Edition Silver
      04-14-2017, 04:12 AM   #2
Leonelm3-X5M
M-Power Dallas !!!!
Drives: 01 Custom HPF 900whp Turbo M3
2010 BMW X5M  [10.00]
2012 BMW X5d  [10.00]
2001 BMW M3  [10.00]
whats available for the X5D?
are they not the same offerings from H&R / EIBACH / DINAN / Voghland for all E7x ?
Leonel aka Rico /// BMWCCA # 403748
10 X5M - Pure Stg.2 turbos/K&N/JB4/Becker 3" Catless DPs/Megan Racing Ti Exhaust/H&R/Rohana RC22s/Vrederstein Ultrac Sessanta/Soon/+BMS+KWV3s+OSSDesign headlights.....
      04-14-2017, 05:39 PM   #3
mitch808
Drives: 2012 X5 35i
Fatter sidewalls, and non-RF-tires.
So that would mean 18-19" wheels, from your 20" wheels.
Of course some tires naturally have firmer or softer sidewalls too...
m5james431.00
      04-15-2017, 12:49 AM   #4
TKR
Drives: 2016 X5 40e & 2018 330e
19" with non runflats is quite a ok. 18 inch even smoother.
But, there is a solution also for your 214's. New Continental Extreme contact DWS06 tires. Smoothest tires on earth in 275/315 size.
And swap your front tensions struts to new ones. Parts 31126773949 and 31126773950. The rubber mounts get loose over years and make steering/suspension feel harsh and "clunky".
      04-16-2017, 07:36 AM   #5
argento
argento's Avatar
538
Drives: 2013 X5M
Your description sounds like the time I blew a rear bladder. Maybe check to see if yours aren't compromised. Also check to see if your 214's are cracked, probably wouldn't affect the ride though...unless it's really bad. My 214's kept cracking, eventually replaced them all. $0.02 Good luck.
      04-19-2017, 12:02 AM   #6
WULFFZA
WULFFZA's Avatar
That's the tires I'm on! It was a significant improvement over the runflats, night and day and I switched over to them within a month of buying the vehicle, but I just don't think there is enough for the broken surfaces of my local roads.
I think you may be on to something on the worn mounts. It doesn't take much on these vehicles to be slightly out of sync and the handling and stability fall apart, even less forgiving on low profile tires - I've experienced similar with all my BMWs.. Going to price this out, but I am only at 52,000miles. Is that fair game mileage to have bad enough wear to make a difference.
      04-19-2017, 12:10 AM   #7
WULFFZA
WULFFZA's Avatar
You may be on to something. I noticed a few months ago the rear seems to drop ever so slightly when its been standing. I also noticed on one diagonal dip I pull through each morning that the left to right wobble is worse first thing in the morning - perhaps that too is sign of a leak, like it is not fully inflated and allowing more sway. I'm hoping that would be covered under CPO warranty if there is a leak?
I tried something else yesterday, I pumped the tires above recommended pressure by ~4 psi over, and the ride smoothed out some (and of course turn in improved!). That seems counter intuitive?
