      01-11-2016, 08:23 PM   #1
JGard
Drives: 24 BMW iX xDrive50
My turns for random check engine light and lots of codes
I was driving home from work in lots of traffic as I usually do. At one point the transmission seemed to refuse to shift up a gear and the engine kept revving around 3k rpm (I have a diesel, so that's high).
I feel like the car's been shifting occasionally poorly for a while, so I thought maybe it was related. Also note I just replaced my battery with a Duralast from Autozone about a week ago, registered with Carly, and it's been driving great since.
As for the codes, here's all Carly shows me
Motor Control:
Code: 004121 DDE Main Relay
Code: 004BAC Reducing agent active tanjk level sensor signal sensor monitoring error
ABS/DSC/Brake:
Code:006EC4 Steering Angle Sensor
Transmission Control:
Code: 0055C3 VGSG wheel Notlaufregelung activated. No DXC desired torque setting
Code: 0055DO CAN Message
Instrument Cluster:
Code: 00A3B1 CAN signal fault indicator
Code: 00A559 Shutdown
Heating/AC:
Code: 009C69 PTC Kit
Immobilizer System:
Code: 00A128 unknown failure
Systems:
Code: 00A6D1 Short Circuit to positive or open circuit - additional water pump
Code: 00E1CF The Central registry is incorrect/unknown fault
So based on the fact that like none of these are related, would it be reasonable to think that it's due to the battery being an issue? Should I perhaps let it trickle charge over night?
The thing that makes me wonder if it's a legitimate problem is the fact that the transmission acted really weird just before the light came on. And that happened a good 25 minutes into my commute
      01-11-2016, 08:31 PM   #2
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
Holy shit... No idea man, sorry... I say suck up the diagnostic fee and just bring it to the dealer and get it done right...
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      01-11-2016, 08:33 PM   #3
JGard
well, to update my own thread here... the voltage on carly says only 11.9V, which, annoyingly, is the same as it used to always show before the new battery.
So I've hooked it up to a battery tender and will let it sit over night.
However, I went to clear all the codes, and all of them went away except for the two Transmission codes. So I guess I may have an actual problem with that...
      01-11-2016, 11:47 PM   #4
TheVazha
Drives: X5Mmmkay.
Just throwing this out there, have you turned off the car, disconnected battery for a couple and then fired her up again?
      01-12-2016, 09:45 AM   #5
JGard
So what I did last night was I tried to clear all the codes with Carly. For whatever reason, it never showed the two transmission codes as having cleared, but I just left it. Then I hooked the car up to my battery tender and let it sit overnight.
This morning as I was leaving for work, I checked the tender and it still said "charging" and not "charged" which was a little disconcerting, but whatever. When I started up the car, no more CE light. Drove to work this morning (15 miles) and everything seemed normal. I know it tends to take a few repeat experiences before a CE light comes on, though, so I'm still crossing my fingers. Perhaps this also means I just have to trickle charge my battery semi-regularly (which is annoying since it's new)
      01-12-2016, 10:20 AM   #6
Nickdm3
Drives: Bmw m3
i am having a similar issue with strange transmission issues. brought it to the dealer and they think it is related to the active tank sensor being bad. i do have a bad sensor and it is going to be replaced on thursday. i will let you know if that is the issue or not. they think it has something to do with the emmisions and the car going into a safety mode.
      01-12-2016, 10:31 AM   #7
JGard
Interesting. Please do update once you get some news.
I went online to make a service appt with my local dealer (I have an extended warranty through them) but the soonest I could make one is for Jan 22nd. So I have two weeks to go. With any luck the light won't come back, but I have a very strong feeling it will.
And you mentioned the active tank sensor, that is one of the warnings I got, so there could certainly be something to it.
My warranty cost me about $2500. So far it's paid out about $700 in repairs. Maybe this sensor could be another costly one to help make that warranty purchase worth it
      01-12-2016, 06:29 PM   #8
JGard
Yep, CE light is back, as I figured it would be. I have yet to check the code. If it's the Urea tank/sensor, so help me god, my warranty better cover it. It did NOT cover my EGR Cooler because it apparently doesn't cover exhaust components. But it did cover a NOx sensor, so I'm hopeful it would also cover this.
      01-12-2016, 08:35 PM   #9
socale39
Drives: 04 545i SMG
My warranty covered the tank so you should be good.
I'm wondering if it's not so much your battery but possibly your alternator. As we all know alternator and battery issues are notorious for causing all sorts of faults and given the long list of error codes you had before I'd be leaning in that direction. Have you noticed any change in drivability when you add a load to it such as running the A/C, radio, fan, etc together?
      01-12-2016, 09:32 PM   #10
JGard
I got to checking the code and it's the DEF active tank sensor. I hope your warranty was aftermarket and not BMW
I checked my list of what's covered and what's not. It specifically says exhaust components, but it generally seems to refer to potential wear items. Like I said in my previous post, it covered a NOx sensor,but it didn't cover EGR Cooler. I should be safe/OK.
Of course I JUST bought myself an e36 M3 as a fun car, so my wife is pissed at the idea I may also have to shell out $2k to get this fixed
      01-13-2016, 08:44 PM   #11
socale39
Drives: 04 545i SMG
I have a BMW warranty and everything was covered for the active tank replacement.
      01-15-2016, 10:49 AM   #12
JGard
All of a sudden this morning, Check Engine light is off. WTF.
I mean, I guess I'm not complaining, but if the DEF tank is failing, just stay on so I can have the dealer fix it already
      01-15-2016, 12:40 PM   #13
HollywoodsX5M
HollywoodsX5M's Avatar
13
Drives: 10 X5M
Motor Control:
ABS/DSC/Brake:
Instrument Cluster:
Heating/AC:
Immobilizer System:
Systems:
I had to replace my battery after the whole time I was having issues, and the dealer saying it's good. Finally I took it upon my self to replace the Battery and bam it works perfect
      01-15-2016, 02:56 PM   #14
socale39
Drives: 04 545i SMG
I had the same experience. Sometimes it would be on, other times it wouldn't. Drivability was the same, no impact. I had to drive around like that for 1.5 months before the part finally came in from Germany.
      01-15-2016, 03:02 PM   #15
JGard
Ah, ok, so this isn't unusual. Sounds like how a failing sensor would act, I suppose. Fine for a while, crap for a while... I'll keep my appointment for next week as I'm sure the code is still stored and they'll be able to read it
      01-15-2016, 03:16 PM   #16
Nickdm3
Drives: Bmw m3
my car is still at the dealer. ill give an update once i get it back.
      01-15-2016, 04:14 PM   #17
H2C
Drives: 2012 X5 35d
Who do you have the aftermarket warranty with?
      01-15-2016, 04:40 PM   #18
JGard
It's just called "Auto Protect"... My local BMW is the one who selected it.
      09-18-2018, 06:40 PM   #19
sk72
Drives: 2006 BMW X3
Couple of days ago I got CEL with P203A or 004BAC (Reductant Level Sensor Circuit) code. Took it to the dealer and they replaced active tank and hose under warranty (10 years/120k miles).
2012 X5 35D
      03-13-2023, 06:34 PM   #20
hartwa
Drives: 2011 335d
Jgard....did you ever figure out this issue. My x5 is doing the exact same thing.
      04-01-2023, 11:28 AM   #21
hartwa
Drives: 2011 335d
Anyone have advice on this? Now a few weeks later the car starts and runs for a few minutes dies giving the dsc xdrive malfunction. Bunch of codes 4121 dde relay 4d36 reduce agent pressure plausibility, cf55 message error reciever dme dde, 6f56 message error dme dde.
I chargec battery overnight and restarted this morning montoring voltage. It started at 12.6 dropped a little during cranking but was at 15 or so while running....for the minute or so before it quiet.
I was going to change relay next but i have not found it yet. Appreciate any advice.
Thanks
      04-01-2023, 03:10 PM   #22
hartwa
Drives: 2011 335d
Btw 2013 x5 35d
