      12-28-2015, 03:22 PM   #1
mjcecil
Sometimes, I wear a cape...
159
Drives: 2014 M5 Black Sapphire
Liftgate/Cargo area clunk
All, I've been tearing my hair out over a clunking noise in either the rear cargo area or the liftgate itself.
The sound happens when the car rocks side to side when going over laterally uneven surfaces, or when bumps are relatively sharp.
The sound is very much like if you had something hard rolling around in a compartment somewhere, banging up against hard plastic or painted metal. It's usually just one "clunk" per motion, and doesn't "bounce," like a rattle.
I've cleared out the spare tire/nicknack well, and looked behind all the panels for loose stuff, to no avail. Is there anything that typically makes this noise on a 60K+ E70 35i?
Thanks!
Mark
Now: '14 ///M5 Black Sapphire Metallic
Past: '15 ///M3 Mineral Grey, '11 X5 35i, '08 ///M5, '06 [S]4, '05 Mini CooperS, '07 [S]4 DTM, '03 ///M3, '99 ///M3, '78 530i, '71 2002
      12-28-2015, 08:07 PM   #2
UglyBuzzard
UglyBuzzard's Avatar
Drives: F90 / M5
Thanks!
Mark
Check rear seat latches - same noise and that was issue - noise gone
      12-29-2015, 11:24 AM   #3
socale39
Drives: 04 545i SMG
^^^ +1
I too thought the noise was coming from the hatch but it was actually the right rear seat latch. Sit in the back and rock back and forth, forward and backward and you should be able to replicate the sound.
      12-29-2015, 11:29 AM   #4
mjcecil
159
Sounds like we have a strong candidate. I'll check it when I get back with thevehicle on Monday. Thanks, Y'all!
So, how did you guys manage to fix it, socale39 and UglyBuzzard ?
Mark
      12-29-2015, 12:01 PM   #5
UglyBuzzard
Drives: F90 / M5
Mark
Warranty repair.
      12-29-2015, 12:14 PM   #6
socale39
Drives: 04 545i SMG
Haven't had mine done yet but next service visit I'll have it done under warranty as well.
      12-31-2015, 06:08 PM   #7
KennyKong
Drives: E70 xDrive35d
Do you have the rear cargo cover? I took that out and the rattling went away.
Been doing some research and it sounds like felt tape is on order to try and cure this rattling issue.
2011 BMW 535i xDrive - Dark Graphite Metallic
2007 BMW 335i Coupe - Space Gray
2002 BMW M3 Coupe - Alpine White
2001 Honda S2000 - Spa Yellow Pearl
2001 Acura Integra Type R #01-686 - Phoenix Yellow
      01-01-2016, 11:03 AM   #8
Diesel X5
Diesel X5's Avatar
Drives: X5 35d X
That can be a tough one to find.My daughters suv had the same kinda noise and I looked all inside and underneath and found that there was a rock stuck inside one of the springs. Problem solved noise gone.
      01-05-2016, 04:29 PM   #9
mjcecil
159
Ahhh. Good thought! If felt tape eludes you, I often go to the fabric store and get stick-on velcro in black, and just use cuts of the loop-side. Do this virtually every time for my seatbelt sockets where they bang up against the console or the seat base.
Thanks!
Mark
      01-07-2016, 02:44 PM   #10
RustyX5M
Drives: e70 x5m
There are two adjustable bump stops on the hatch surround. T25 (?) torx screw to adjust them outward/inward. Make sure they are the same offset and outward enough to contact the hatch when it closes but not enough to make it go back up/stop before latching.
This should fix the clunk.
      01-08-2016, 04:07 AM   #11
Tritan84
Drives: 2011 535i
Also check the actual latch on the tailgate. Mine was loose from the get go. Just needed to tighten 2 bolts and the clunk was gone. Seems obvious, but even the techs at BMW didn't catch where it was coming from. They just assumed it was from the cargo cover.
