      01-07-2017, 02:22 AM   #1
Adzh-X5m
Dan
Drives: 2010 Bmw x5m
Brake job on my x5m
Just wanted to share my new brakes I just finished on my x5m, since I couldn't find anything aftermarket and didn't want the same ones I got these!! Seen couple people on here do it and love the way it looks. Ran out of time couldn't finish the front ones.
      01-07-2017, 10:01 AM   #2
socale39
Drives: 04 545i SMG
Looks awesome. That rear caliper almost looks lost with all that rotor
      01-07-2017, 11:02 AM   #3
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
Great job, this is in my plans as well!
      01-07-2017, 12:16 PM   #4
bimmerNovice
Drives: 2011 X5 M
WTH? you did all that drill work yourself?
What do you suppose the actual detriment/benefit analysis to be for the braking/cost etc?
      01-07-2017, 07:07 PM   #5
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
I've seen this done on some other trucks, looks great! I plan on this when I need to replace mine also. The price is actually about the same if not cheaper depending on where you buy. Using bolt on spacers in the rear eliminates any problems with the lack of an aligning rotor bolt in the rear.
      01-08-2017, 12:29 AM   #6
Qarban
Drives: E70 X5 and E70 X5M
Those are oem F85/86 rotors, drilled by brembo
And like a lot of us here, this is also on my list when it's time to change my truck's rotors
      01-08-2017, 12:33 AM   #7
Qarban
Same here. I think at least 25mm + spacers are bolt ons.
      01-08-2017, 11:26 AM   #8
madmille28
Drives: na
So to be clear the F85 M rotors will clear our stock E70m rims with spacers. But what if we wanted the entire F85M setup with rotors and calipers. Will we need 21" wheels to clear the F85M rotors and calipers?
      01-08-2017, 08:04 PM   #9
Adzh-X5m
Dan
These are same size as oem, and I did it because it was time for new brakes. And the cost was less than I'd pay for any other brakes considering it all came out to under 1500 and it looks a 100 times better and more effective than the original ones on our trucks!!
      01-08-2017, 08:05 PM   #10
Adzh-X5m
Dan
The only pain in the ass was removing the rotor holding screw.
      01-09-2017, 05:54 AM   #11
Qarban
You can install them with the stock 20" wheels because the E70 M and F85/86 rotors has the same diameter and thickness. No need for spacers for clearance if you are installing them on E70 M, the only purpose (but not a requirement) for installing bolt-on spacers for the rear because the holding screw opening of the F85 rotors doesn't match the E70 M which means the rotors are being secured only by the oem bolts of the E70, if you have to install bolt on spacers, the bolts of the spacers will hold them in place. The front rotors can be held by the oem holding screw.
      01-09-2017, 07:53 AM   #12
madmille28
Drives: na
Thank you for the clarification. Can we also install the F85M calipers as well on our stock 20's without any issues?
      01-11-2017, 09:12 PM   #13
JMD
MGySgt
JMD's Avatar
Drives: See Garage List! ;-)
2010 M5  [10.00]
2016 BMW 340xi M Sport  [9.00]
2019 X5 50i M Sport  [5.50]
2010 535xi  [0.00]
2013 M5  [0.00]
2012 X5 M  [0.00]
Is this a pic of a complete unit,...rotor hub and rotor or just the rotor? I ask because your rotor hub is crazy clean!
JMD
      01-11-2017, 11:26 PM   #14
Adzh-X5m
Dan
Haha no only rotors and pads, New England weather will rust out everything!!
      01-11-2017, 11:28 PM   #15
Adzh-X5m
Dan
The calipers are oem on the m, the rotors are same size only difference is the appearance and the way the rotors are made.
