      04-19-2018, 05:28 PM   #1
ISMERX5
ISMERX5's Avatar
Drives: 2012 BMW X5 35D
DSC Malfunction
I installed new rims and got a DSC Malfunction on my 2012 BMW X5 is it true i just have to recalibrate steering wheel to get this code out ?
      04-19-2018, 10:42 PM   #2
RichardR0404
Drives: 2013 BMW X5 35D
try crank the wheel all the way to the left and right and see of its go away.
      04-24-2018, 01:40 PM   #3
ISMERX5
ISMERX5's Avatar
That doesn't work
      04-24-2018, 03:54 PM   #4
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
http://www.xbimmers.com/forums/showthread.php?t=1484792
      04-28-2018, 12:00 PM   #5
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Can you give us a bit more information so that we might be able to help you better? Are the new wheel/tire combo the same size as before or did you change the wheel/tire combo size?
If you changed from what BMW recommends (see your owners manual or the tire inflation chart on your driver's door)...then you will have needed to stay within 3% overall rolling diameter/circumference so that the wheel rotation calculations for the AWD and DSC systems aren't way off base.
If you installed staggered wheel/tires...did you check to make sure the correct tires were mounted to the correct wheels...and that the correct wheels were installed on the correct axle?
