10-12-2009, 02:27 PM | #1 |
Rep 122
Asking about the possibility of installation 21 Inch Style 215 Ferric Gray for X6 V8
Hi All ,
Can i put the wheels (Style 215 Ferric Gray -21 inch- ) on X6 xDrive 50i ? Are there any problems that i'll face if i fix them on my car.. such as noise , Vibration or off-balance on the road ? Because the standard wheels comes from the factory are 20 inch .. so i want to know that can i put 21-inch without problems .. Please I'm looking for someone tries 21 inch Wheels .. To advise me Thanks .. |
10-12-2009, 02:40 PM | #2 |
Scott R.
22
Rep 270
Drives: X6 xDrive 50I
I have the gloss black 215s on mine and have no issues. They certainly attract a lot of attention. Here are pics on another thread. I have the 50i also.
http://www.xbimmers.com/forums/showthread.php?t=289310
Scott - 2012 BMW X6 50i Twin Turbo / Porsche 996 Twin Turbo
Black Sapphire Metallic with Saddle Brown Nevada Leather, Comfort Access keyless entry, Running boards, Rear-View Camera, Dark Bamboo wood trim, HUD, HD Radio, Satellite Radio, Cold Weather Package, Premium Package, Premium Sound Package, Rear Climate Package, Sport Package, Euro Black Kidney Grill, Euro Side Markers, Black Double Spoke 215 Wheels... |
10-12-2009, 03:32 PM | #3 | |
Rep 2,087
10-12-2009, 03:42 PM | #4 | |
Rep 122
10-12-2009, 03:45 PM | #5 |
Rep 122
10-12-2009, 04:18 PM | #7 | |
Rep 2,087
If you want a stealthy, tough look, then go with the black, but if you want a somewhat brighter slightly more sophisticated look then go with the grey. I'd be happy either way, but as you can see the ferric grey will look very good! |
10-12-2009, 04:24 PM | #8 | |
Rep 2,087
10-13-2009, 06:28 AM | #9 | |
Rep 122
10-13-2009, 06:33 AM | #10 | |
Rep 122
10-13-2009, 06:43 AM | #11 | |
Rep 2,087
http://www.bmwusa.com/standard/conte...1pDTSKi7ovMPM= |
10-13-2009, 06:54 AM | #12 | |
Rep 122
10-13-2009, 08:15 AM | #13 | |
Rep 89
Drives: 2020 X7 M50i
I don't think that is completely correct. They do add a small piece of grey plastic which goes on the inside of the wheel arch and protrudes slightly. My understanding was that this is to prevent too much splashing from the bigger wheels. It will not however make you car any higher. I too has the factory 20s and changed to the 215 in ferric grey. D |
10-13-2009, 10:32 AM | #14 | |
Rep 122
Thanks now i get it . Do you feel any difference when you install the 21s wheels ? like uncomfortable when you drive it ? & u told me the car will not be higher than before ,, and it'll still remain @ the same standarded high am i right ? My brother told maybe your car will be higher than before & it'll be Ugly scene, on what u said i think he's wrong . |
10-13-2009, 04:02 PM | #16 | |
Rep 89
Hope it helps a bit! D |
10-13-2009, 07:21 PM | #17 | |
Rep 2,087
Below are charts taken from the tirerack.com and the Dunlop websites. The upper charts are from tirerack.com indicating what sizes are typically available for X6 5.0i wheel diameters from 19" -21". The long black/gray charts are from Dunlop's website and shows the actual specs for the available tires sizes available for wheel diameters from 19" -21". On the Dunlop charts the critical thing to look at is the column labeled "Outside Diameter". You will note that for outside diameter sizes for the 19", 20" and 21" tires are virtually the same. Only the 19" varies by .1" from the other sizes. |
10-13-2009, 08:24 PM | #18 | |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
There you can put the size of your actual tires against the new ones, then you will see the real difference, sometimes going 1 size up on the wheels, you got 1 size down on the tire sidewall height, so you can end at the same height, hope it will work for you |
10-13-2009, 08:37 PM | #19 | |
Rep 2,087
I plugged in the two most extreme Dunlop sizes 255/50-19 vs 325/30-21, which on the Dunlop web site (see charts above) indicate have the same outside diameter, but you'll notice that TIRECALC indicates they are different. It was right on for the size comparison of Dunlop sizes 275/40-20 vs 325/30-21. |
10-13-2009, 10:36 PM | #20 |
524
Rep 2,146
well, you got me with this one.......it will be great that someone here knew how to make those numbers to see which website is closer to reality, anyhow, good luck with your choice
10-14-2009, 12:57 AM | #21 |
Rep 2,087
I think it's good for general info because it has to make assumptions for a lot of manufactures, that's all.
