05-17-2017, 06:45 PM | #1 |
Rep 263
Drives: 2013 E93 M3 Jerez Black, 13 x5
Garage List 2017 GMC 2500HD denali [0.00]
2018 Tesla Model 3P [0.00] 2020 BWM x7 m50i [0.00] 2013 BMW X5 [0.00] 2013 BMW M3 E93 [0.00] |
garage door opener
I can't seem to program my 13 X5 opener. I followed the instruction in the manual and doesn't work.
I have a 2013 M3 followed the instructions and it works just fine, on two separate doors (in the same house). Is there something different about 2013 X5 garage door opener? Is it possible that the opener is defective. I cleared the memory multiple times as instructed prior to trying different things. thanks. |
05-18-2017, 07:05 AM | #2 |
Rep 18
If it is a "HomeLink" type set up, there are you tube videos to help.
I had a GMC Acadia I had trouble with and called HomeLink and someone there walked me through it. Also do you have a learn button on the opener itself? Are you pressing the learn and car buttons in the proper sequence in the allotted time before either times out of program mode? Just a few thoughts. |
05-18-2017, 09:10 AM | #3 |
Rep 66
as I recall, for the homelink the car has to be really close (right under) to the the garage door opener to be programmed. I have craftman, to program, u press the learn button on the opener, whitin 30sec, press and hold one homelink button, opener lights flash 3 time once sync successfully completed.
05-18-2017, 06:49 PM | #4 |
Rep 872
I just did this a few weeks back. I have an X5M, my owner's manual says pg.135, but go to index and look up Universal Garage Door Opener and get the right page.
On that page you'll find the UGDO section and under there is a section called PROGRAMMING. Follow these procedures exactly. With the car in range of the ugdo, program the appropriate button, be sure to start by zero-ing out all the programs. FYI , I parked the truck outside of the garage about 15ft from the door. If it doesn't work, then perform this check...if you did everything right in this procedure, and it's not working, then when you press the programmed button it will flash rapidly and then lights up continuously for 2 seconds indicating that you have an alternating code system. Then go to the next set of procedures labeled ALTERNATING CODE RADIO SYSTEMS and follow those procedures exactly. I had a 2013 X5 3.5 and I had to use these same exact procedures back then.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 Last edited by argento; 05-18-2017 at 07:27 PM.. |
05-18-2017, 10:30 PM | #5 |
Rep 2,736
Also if you bought it used their may be old codes already set to the past owners garage door. The dealer should have done that but sometimes they forget. so you'll need to erase all old settings first then do the pairing with your garage door. If theirs already a code in their it won't let you just write over it so you need to wipe it clean.
If you've already done that then I'm not sure why you're have an issue. |
05-19-2017, 10:57 AM | #6 |
Rep 728
I did this with the wife's E70 and my E70 and hers went fine but mine wouldn't save the freq for some time. I followed some instructions off YouTube that a dealership put up. Both were parked under the opener. In the end I just had to hold the button down longer on mine...like maybe over a minute and it finally saved.
05-19-2017, 11:31 AM | #7 |
Rep 119
Research programming 'rolling code' or 'alternating code' with homelink.
I seem to remember having to hold a currently programmed opener up to the BMW so it would learn the freq, then you do the usual steps of pushing learn on the motor and pushing the button in the BMW.
2011 E70 35i MHD Stage 1+ (current)
2008 E90 335XI FBO, Meth, E85 (sold) |
05-19-2017, 03:48 PM | #8 |
Rep 1,292
Depends on the opener as well. I have a Sommer opener and I can not get it to accept the homelink program no matter what I try. I just gave up after several days and hours of attempts.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
05-20-2017, 12:16 PM | #9 | |
Rep 387
Drives: 2013 X5 3.5 Premium
Garage List 2013 X5 Premium 3.5 [0.00]
2020 Chevrolet Subu ... [0.00] 2018 Mercedes E400 ... [0.00] 2017 Nissan Titan SV [0.00] 2008 Porsche Cayman S [10.00] |
Well he did and sure enough he programmed it. I don't know which link he used but it involved a video of a guy with an E93. He said it worked on the first try. |
05-21-2017, 09:03 PM | #10 |
Rep 263
thanks everyone for their advice. I got it to work. Are there TWO versions of the X5 manual?
Here is what the manual I found online says: Synchronization: 1. Park the vehicle within range of the re‐ mote-controlled system. 2. Program the corresponding button on the interior rearview mirror as described. 3. Identify and press the synchronization but‐ ton on the system being set up. You have approx. 30 seconds for the next step. 4. Press and hold the button on the interior rearview mirror for approx. 3 seconds and then release it. Repeat this step up to three times if necessary to complete the syn‐ chronization procedure. When synchroni‐ zation is completed THIS IS DIFFERENT from the actual book that came with the X5. Here is what the book (Page 125, online version has it on page 140) that came with the X5 says: 1. Park the vehicle within range of the re‐ mote-controlled system. 2. Program the corresponding button on the interior rearview mirror as described. 3. Locate the button on the receiver of the device to be set, e.g. on the drive unit. 4. Press the button on the receiver of the device to be set. After step 4, you have approx. 30 seconds for step 5. 5. Press the programmed memory button 1 of the integrated universal remote control three times. The corresponding memory button 1 is now programmed with the signal of the original hand-held transmitter. anyway, I'm glad it works..... |
05-21-2017, 09:08 PM | #11 | |
Rep 263
Trying to answer my own questions. ...
The copyright date on my hard copy manual says, 2010. The X5 I have is a 2013 model year. The PDF online version copyright year is 2012. So I wonder why mine didn't come with the 2012 version. That would have solved mos tof this. Quote:
05-22-2017, 07:09 AM | #12 |
Rep 1,685
I tried this again after giving up a year ago. Took me about 30 seconds to program the opener at my parents house. Would NOT budge at my house. The clicker just won't pair with HomeLink in the car. Tried different angles, distances...no luck.
Did some research. Apparently BMWs have HomeLink 3.0 and it works flawlessly with older garage door openers, rolling codes or not. However, if you have a newer opener, last couple of years or so, they come with HomeLink 4.0. The two are not compatible. You have to get some sort of "repeater" installed to take advantage of HomeLink in the car. The repeater itself comes with a host of issues, range being one of them. If anyone was able to pair a new garage door opener (HomeLink 4.0/Security+ 2.0) with your car I'd love to know how... This was bugging me a year ago and it's now bugging me again after reading this thread. |
05-22-2017, 01:54 PM | #13 | |
Rep 263
geez.. |
