      09-23-2014, 07:30 PM   #1
moeenulhaq
Drives: 2011 X5
Rear spacers
Looking for good 20mm rear spacers with bolts - Any recommended brand?
      09-23-2014, 10:22 PM   #2
mitch808
Drives: 2012 X5 35i
H&R is a very solid brand that is usually stocked at a lot of places, or can be dropped shipped pretty quickly too.
      09-24-2014, 09:58 AM   #3
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
unsprung weight's abt 10x , a 10lb spacer could mean 100 lbs ... reason I've never added them, on a separate note apexraceparts makes the lightest ones I heard
      09-24-2014, 10:57 AM   #4
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
A 20mm aluminum spacer weighs...what? a few ounces?
Compared to the ~75 pounds each rear wheel and tire weighs, depending, it's pretty negligible.
lolz
      09-24-2014, 11:43 AM   #5
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
lolz
its not unsprung if it's bolted to the hub. Its a total non issue.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      09-24-2014, 02:13 PM   #6
mitch808
Drives: 2012 X5 35i
Agreed. It's a non-issue.
Bolt 10lbs to the edge of the rim, or run a heavier tire, then that's a problem for acceleration...
Granted 10lbs does affect suspension responsiveness, but it's minuscule in the current state.
      09-24-2014, 02:35 PM   #7
upstate650
upstate650's Avatar
They only weigh ounces, not pounds. Running forged wheels with non run flat tires shaves off approximately 30 lbs a CORNER! now THAT is un-spung weight!
      09-24-2014, 05:32 PM   #8
rennis
rennis's Avatar
43
Just by switching from BStone RFTs to Conti DWS, I think it's almost 15 pounds per side in the rear. Unreal.
