      09-21-2014, 01:18 PM   #1
vchris
Greece
Drives: Bmw 220i Sport
X5 4.8i 2008 wheel change
Hello to all my name is Chris,
I am considering changing the wheels from factory 18' to 20' and I was just wondering if I can avoid the enormous 315 tyre at the rear because i think that it's too wide and a bit not aligned with the body of the car.
I know that 20's come with 20x10 ET40 FRONT and 20x11 ET37 REAR
What other choices can you suggest without affecting ride of the car.
Thanks in advance
      09-21-2014, 08:00 PM   #2
PAX5
Drives: 2012 X5 50i
Get a square 20x10 wheel set.
Select a tire that will fit a 10" wide wheel, e.g. Michelin Latitude Tour H/P. You can use size 275/40-20 or 274/45-20. The 275/45-20 is slightly taller and gives you a bit more cushion with a 20" wheel ride ...
PAX5
BMWCCA 20645
