      08-08-2017, 01:52 PM   #1
335dsleeper
Drives: 09' 335d 10'35D
35d H&R install and Bilstein upgrades
I recently started getting a very annoying rattle going over bumps. I swapped the sway bar end-link and both lower control arms. The noise was still there. I assumed the noise was coming from the upper strut mount so, I ordered a set.
I also ordered Bilstien sport struts, the shorter ones designed for lowering springs to match the H&R sport springs I ordered a few weeks back. I opted for the 2" version. This weekend I had the time to install everything.
The drivers side bushing that goes above the strut mount and under the washer and nut was literally gone. Part #10 in the diagram.
https://www.realoem.com/bmw/enUS/sho...diagId=31_0791
I replaced 8, 9 and 10 and 7 came with the new struts.
The install was straight forward and only took a few hours. The front is a noticeable drop of just over 2.5" and the rear was even lower, close to 3.5" with the rear links at the 65mm H&R recommends. I turned the links 4 full rotations and now, the rear ride height is 2" lower than stock and ride is perfect. Zero bounce etc. The distance from the ground to fender flare is 29 13/16 in the front and exactly 30" in the rear.
The front struts along with the springs is a perfect combination. It rides great and has literally transformed the X5. Bilstein says the sport struts and shocks are not designed to work with 3rd row seat or self leveling. I said screw it and ordered them. The front is absolutely perfect and I just ordered the rear shocks to match. The sport shocks are designed to work with lowering springs so, with the rear being 2" lower than stock, the shocks should improve ride quality and handling over the stock shocks.
I was initially concerned with the air ride warning etc but, now that the ride height is set, the X5 will always target that ride height regardless so, i do not see how or why we cannot use the shocks. I'll update once I install the rear shocks but, for now, the front is absolutely perfect. It rides great and there is no bounce. It feels better than stock and much sportier!
      08-08-2017, 08:55 PM   #2
Doctor///M
Doctor///M's Avatar
Drives: 2023 AUDI RS6
2023 Audi RS6 Avant  [0.00]
BMW M2 Competition   [10.00]
2009 BMW 335i  [0.00]
2015 M3  [9.52]
Fantastic! I'm definitely not skilled enough to install new suspension, so I'm leaving it to a shop to do it. I'm looking into the Dinan spring/ride handling kit. Will report back on the ride quality versus stock. Not too many posts with detailed info on new setups, so much appreciated!
2020 F87 M2 Competition /l\ LBB /i\ Executive Package
2013 E70 X5M /l\ Space Grey /i\ Full Silverstone Leather /l\ LED Headlights /i\ Comfort Access /l\ HUD /i\ Ventilated Seats /l\ 22" BBS SV
BMW CCA Member
      08-14-2017, 05:35 PM   #3
335dsleeper
***Update***
The rear Bilstein's wont fit. Boo!
We've put roughly 500 miles on the X5 since the I installed the springs ad front Bilstein struts and we're very happy with the ride quality, handling and overall look the vehicle.
Unfortunately the Bilstein sort shocks will not work with the rear air suspension. The Bilstein shock tube is 1.5" longer than the stock (with air suspension) shock and is too long to fit properly.
We're loving the X5 now. I do wish the rear Bilstein sport shocks would've fit but, it's OK as the rear shocks work fine.
Here's a quick pic.
      08-18-2017, 01:43 PM   #4
mitch808
Drives: 2012 X5 35i
Which bilsteins are these? B4, B6, or B8?
      08-18-2017, 09:37 PM   #5
335dsleeper
Looks like B8. Part number 24-143967
      01-26-2020, 01:49 AM   #6
robinasu
Drives: 2012 E70 BMW X5d
Nice
Looks good- what size wheels are in the picture?
Originally Posted by 335dsleeper View Post
***Update***
Here's a quick pic.
      01-26-2020, 06:38 PM   #7
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
20" 214s
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      01-27-2020, 08:47 PM   #8
robinasu
Originally Posted by sunny_j View Post
20" 214s
Thanks!
      02-21-2020, 03:51 PM   #9
robinasu
Guys, what bump stops are people using with the B12 kit?
      02-28-2020, 11:24 AM   #10
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
I'm running unmodified factory sport bump stops all around and I don't think I've bottomed it out yet
Build Thread
      04-30-2022, 01:38 PM   #11
robinasu
Late to the party
Ok, I ordered the B12 kit. Hope it comes soon.
When you say sport bump stops, do you mean the X5M stops or the F10 M5 bump stops?
