      08-11-2014, 04:33 PM   #1
Lucabratsi
Drives: 2013 X6M
Left/Right height differential with Dinan suspension?
Hello,
I had a Dinan suspension installed at my dealer. 4 weeks later, the left drivers side is 22mm higher than the right side. Dealer states this is normal.
Anyone with Dinan suspension compared left/right levels?
Thanks,
      08-11-2014, 11:35 PM   #2
Jess///M
Drives: 2016 X6M
I've had mine for 3 years and it's perfectly balanced to my knowledge.
      08-12-2014, 02:51 AM   #3
daytona1712
Indonesia
Drives: X6M
Hi Lucabratsi
22mm different and they said normal????
I think its easy fix...can be adjust from the link or by computer.
      08-12-2014, 02:55 AM   #4
daytona1712
Indonesia
Drives: X6M
Hi Jess
Would you mind to inform us what is the height of your X6M measured on center of the wheel from floor to fender?
Highly appreciated for your info.
      08-13-2014, 07:49 AM   #5
Lucabratsi
Drives: 2013 X6M
Originally Posted by daytona1712 View Post
Hi Lucabratsi
Yes, just verified the L:R differential of 2.5cm at the dealer, measured from the center of the wheel to the inside top of the fender well. They say this is just in spec. I say the car is grossly tilted. I have been trying to get in contact with Dinan tech support...............not very easy. Calling and leaving messages to someone in tech support who doesnt even give his name on the recording. Does anyone have the Dinan L:R differential spec they can share?
Cheers,
      08-13-2014, 09:25 AM   #6
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Cheers,
I want to know this as well. Mine is 45.7 for three corners and rear driver is 44.5. I am sure this is in spec, but would like to confirm actual Dinan spec. Don't call the CS line call the sales line and have them transfer you.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      08-18-2014, 09:45 AM   #7
Lucabratsi
Drives: 2013 X6M
Hello,
I did get a great response from Dan at Dinan. Their left/right height variance specification is the same as BMW: +-10mm. However, the car should be set up with 0 differential. The spec is the maximum variance. My M is back with the dealer since Thursday, and they are fixing. Will update.
Thanks, to all,
Cheers
