01-30-2012, 02:55 PM | #1 |
Rep 372
Loose Trim?
I just noticed that the rubber trim on the driver door was not fitted properly or maybe came loose in the car wash (Touchless car wash, no brushess). This is the rubber trim that is directly under the side mirror. I have attached a pic that shows it is raised when it should be fitted even against the door. I was able to push it down into place (heard a click) but now there is a very small gap on one part of the mirror where it touches the rubber trim. Was it possible that the when the car wash spray the high powered water it pushed the trim up? If it did push the trim up it would also pushed the mirror up which I think is unlikely since the mirror is attached by 3 torx bolts.
