      03-04-2015, 08:33 AM   #1
naikai
Drives: X6 335i
engine malfunction in the morning and at cold engine
hello please help me out. i got warning "engine malfunction reduce power" at start up in the morning or either cold engine start within a day. i have to leave them run for 15 mins or drive for a while and shut them off and re-start the engine so they will be back to normal. i got error on intake solenoid and have replaced with reset the error but the error still come back in the morning again. Anything i must replace or check it. by the way, i replaced both solenoid as well but still have the same error. thank you for your help. N54 eigine.
      03-06-2015, 12:40 PM   #2
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
I had the same symptoms on my previous 50i , it turned out to be bad injectors.
May not be the same issue but sounds similar.
2022 X6MC - 2011 335D
      03-06-2015, 03:20 PM   #3
big_al_Z
Drives: 2010 x6 50i
If it's the injectors, it should be covered under the "customer care package"
