      04-04-2015, 12:01 PM   #1
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
X5M Wheel spin?
Does anyone ever get wheel spin, I don't even in the rain. I have great new VRED 275 front and 315 rears tires but with 630hp and TQ with the tune I would expect some. did a few launches yesterday with wet roads and not a squeal. The car pulls like a beast almost scared to do it often worrying I will break a tranny or rear end ect. As my buddy said yesterday, this thing is like a ride at six flags.
I didn't know I couldn't do that. But I did know I couldn't do that.
      04-05-2015, 09:59 AM   #2
mhkm
The Doctor
mhkm's Avatar
14
Drives: 2007 E92 335i; 2013 E70 X5M
Disable DSC for cool four-wheel burnouts!
But that's about it.... no doughnuts or fishtails with this beast.
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW.
      04-06-2015, 06:42 PM   #3
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
You must need high horsepower to smoke an X5 with DSC OFF. I have tried it in the wife's 50i and it just launches without a hint of spin. The 275/315's are a lot of meat to try and break loose
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      04-07-2015, 07:21 AM   #4
neliconcept
Fashion Photographer
66
Drives: 2013 Porsche Cayenne GTS
I've broken loose my 4.8 on the wet and on dry, but not from a launch, just a good drift!
      04-07-2015, 01:00 PM   #5
mhkm
The Doctor
mhkm's Avatar
14
From what I understood, he's talking about X5M (550hp stock). With a tune and DP's that's good for over 600hp easy (waiting for install!)
      04-07-2015, 01:11 PM   #6
infamousdiz
with down pipes and stage 2+ tuning 700HP easy
      04-07-2015, 01:18 PM   #7
mhkm
The Doctor
mhkm's Avatar
14
Do you have these installed Diz?
      04-07-2015, 01:52 PM   #8
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Not even close.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      04-07-2015, 03:35 PM   #9
infamousdiz
for 24 hrs, much too loud for a daily driver
      04-07-2015, 03:37 PM   #10
infamousdiz
Originally Posted by Rated M Roadster View Post
Not even close.
why not? 700 at the fly wheel, without doubt. was not speaking at the wheels
      04-07-2015, 04:25 PM   #11
Rated M Roadster
160
Not even close.
Stage 2 tunes don't even make 600 at the flywheel (most around 580); how would downpipes add another 100+?
      04-07-2015, 06:13 PM   #12
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
this power number completely depends on how you are calculating it, however, most stage 2 tunes are rated at more than 600, usually 620 -640, unless you have a Dinan tune. With a catless downpipe and exhaust, the car can gain another 25-35whp, not sure if it's at 700, but I would reasonably believe 670+
as for wheel spin, it has never happened to me when accelerating in dry conditions, and I have catless+full exhaust
      04-07-2015, 06:27 PM   #13
infamousdiz
What shitty tune have you invested in?
http://velosdesignwerks.com/
their numbers are in the Miami heat
      04-07-2015, 06:31 PM   #14
infamousdiz
670...close enough.... velos makes a stage 2+ (almost stage 3) tune for catless down pipes that I once put on
      04-07-2015, 07:11 PM   #15
Rated M Roadster
160
Most stage 2 tunes do not see more than 600. See below...
The same tune you did, Velos.
Let's explore...
First, we have the graph, which is nearly identical to the advertised tune by AA. The difference being SAE vs STD correction.
AA -
Velos -
So let's look at the gains, including the ones advertised. We'll look at AA's graph in a spreadsheet:
[url=https://flic.kr/p/8S3EPK
AAX6mSWLog[/url] by
Active Autowerke
, on Flickr
We'll focus on WHP. Stock, it shows a PEAK WHP of 454. With the tune it shows a PEAK WHP of 473. The key word here is PEAK, as in the amount gained at the highest HP rating. The gain of 86 WHP is NOT PEAK gains; it is in the mid range. Your actual PEAK gains are ~19 WHP. Now let's convert that to HP at the flywheel. If 454 WHP is stock and the S63 engine is rated at ~555 HP, that gives us a ~18% drivetrain loss. Let's take our WHP rating after the tune and apply that 18% drivetrain loss; we get 578 HP. Same applies to the Velos tune.
Where did you come up with 700!? Downpipes and a stage 2+ tune do not make over 120 HP.
      04-07-2015, 07:32 PM   #16
infamousdiz
Let's explore...
AA -
Velos -
AAX6mSWLog[/url] by
Active Autowerke
, on Flickr
this "data" and "facts" are erroneous on all accounts. Maybe you are correct, and by maybe I mean you are. the TQ is through this roof though.
      04-07-2015, 08:46 PM   #17
theaudir8fan
Rated M Roadster hence why I said depends on how it's calculated, the way you are doing it is proper, however, most of these tunes are advertised at 620-640HP. In terms of how accurate this is, it's very hard to tell. But at the same time, BMW have been known to underrate the engine output from the factory, and the stock 555HP isn't necessarily accurate either. I think we should settle for the advertised power output to operate on a equal/reasonable basis, as for accuracy of power rating, it will change depending on the exact car, the configuration, the location, the weather, and many more
      04-12-2015, 10:02 PM   #18
mrmomo313
mrmomo313's Avatar
Drives: M6 Gran Coupe
OP with Traction control turned all the way off and using launch control it is easily possible to to break traction at all 4 wheels. My friend is able to do it on his bone stock x5m with LC, and with the power I'm making it happens on cooler nights quite a bit. Most of the time it hooks pretty well with minimal wheel spin though
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension
2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown
DME Stage 3
