      03-29-2015, 03:44 PM   #1
dougieefresh
Drives: E70M
on a hunt of a E70M
hello fellas,
a little about me, last summer i was so close of trading in my GR subie(stgII) for a F30 M performance but in the end i decided to keep the subie.
the itch for a BMW has come back, so the last month or so ive been looking around to see what fits my criteria. test drove the F30M again(6spd) hated it. IMO the F30 NEEDS to be in the auto version. which none are on sale in my area. so that leads me to the E70M found one at a local dealership. 11 white/red, with just under 70k(km) and of course after much research its a safe bet to buy extended warranty. however i do plan on bringing it in to a indy shop to do a PPI and if that checks out i will most likely doing the switch. and finally my question is i do plan on keeping the car for a good 4-5 years so by then it will be shy of a 10 year old M. in that time frame i will probably put another 60-80k(km) i do have a daily for me to drive to work and back. and like many have asked before, how reliable is a 150k+(km) of course with maintenance done on time, every time. and lastly i do plan on changing oil around 5-8k depending how i drive it
anyways that is my situation hope to learn tons of info!
      03-29-2015, 04:33 PM   #2
PAX5
Drives: 2012 X5 50i
Reliability and M are just not congruous ... change your expectations and you may find a reason to make such a silly purchase decision.
      03-29-2015, 05:10 PM   #3
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
When you wrote F30M are you talking f30 M-sport or f8x ///m car. I only ask that to understand if your talking about an E70 x5M or a e70 M-sport?
The S63 has had the same engine issues which has been covered in the N63 Customer Satisfaction recall but the S63 has not been part of that. Issues involve fuel pressure issues, EGR, coolant hoses as well as injector issues. As for any M car, they require more maintenance above and beyond BMW's recommended intervals for longer life and service/repairs always cost much more when you add the ///M to the car.
If you get into a ///M car and issues arise, just know you will have greater cost. If you can afford it then it is hard to beat an ///M car.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      03-29-2015, 08:16 PM   #4
dougieefresh
Drives: E70M
thanks for the advice guys
F30M i am referring to the 335xi M performance edition. which only had a limited run.
since all the indy shops are closed for the weekend, i will be calling a couple of shops tomorrow to get an idea on repairs/maintenance on the M.
      03-29-2015, 08:51 PM   #5
lanbrown
Drives: BMW X5
There is a saying, if you have to ask, you can't afford it.
If you are going with an extended warranty, many warranties require an existing warranty to be active.
      03-30-2015, 10:09 AM   #6
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Is this a CPO, does it come with a warranty? You should be covered for 2 years after the initial 4 year warranty expires, then purchase the extended warranty. I see no reason not to buy the X5M, It should last you 5 years, easily, if its not your daily driver. The two main issues with the E70 are the injectors and the front drive axle, both will be covered by BMW in the event they fail.
Edit;
Just got off the phone with Carchex they quoted me, at the end of my CPO warranty in 2017.. between 3-4k. To me thats not bad at all.
      04-01-2015, 10:49 PM   #7
dougieefresh
Drives: E70M
that is one of the reasons why this M is on the lower priced side. it is not CPOd. however i did purchase the extended warranty 3years/60k which is bumper to bumper(main concern was the injectors, 8k job -_-)
i am picking up the M tomorrow after work, i CAN NOT wait
      04-02-2015, 11:55 PM   #8
dougieefresh
Drives: E70M
since my car is used there is a cover(sensor?) on the rear bumper that falls out like a gas cap and hangs on. im tryin to come up with a solution to keep it in place but i am out of ideas.
you guys know what im talking about?
      04-03-2015, 09:44 AM   #9
MRV99
MRV99's Avatar
That is probably the rear two hook cover. When it falls out, you should see a threaded hole which the tow hook can screw into. If the cover keeps falling off it may be broke and you may need to buy a new one
      04-03-2015, 01:38 PM   #10
dougieefresh
Drives: E70M
Its a circular cap. On the left side same circular cap on the right side as well. Is it a tow hook
      04-03-2015, 01:43 PM   #11
mleun481
Drives: 2013 X5M
How much was your warranty? I assume you went through 3rd party?
      04-03-2015, 10:25 PM   #12
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
I just got quoted 4200 for 4 years and 60k miles. bumper to bumper 100.00 deductible
I didn't know I couldn't do that. But I did know I couldn't do that.
      04-04-2015, 08:42 AM   #13
mleun481
Drives: 2013 X5M
Is that from a dealer?
      04-04-2015, 10:30 AM   #14
retusn
retusn's Avatar
Drives: 2013 X5M
Yes those two cover the rear tow hook and there are two up front as well. I've lost two of the rear covers. It seems strange to only happen after the M has been to the dealer.
It cost me $50 for the two with paint.
2013 E70 X5M
2011 E92 M3 traded in, 2009 CTSV LEMON, 2008 Z06 Lemon Law, 2007 Z06 Dealer butcher, 2004 Z06 (Sold)
1996 GrandSport (sold), 1996 Impala SS (Sold)
      04-06-2015, 06:19 PM   #15
dougieefresh
Drives: E70M
thanks for the heads up! and no i did not go 3rd party warranty.
im gonna call a couple of indy shops and see if i can purchase warranty after my dealer warranty is up. is that possible?
another question is and pros/cons driving in M mode 24/7? cause thats what i tend to do as soons i start up the V8 i have a habit of turning on M mode. same with my subie, i get in and instantly turn on sportsharp mode for maximum power output.
      04-06-2015, 06:36 PM   #16
MRV99
MRV99's Avatar
I drive my M3 with the ///M settings most of the time. I the x5, I have adaptive drive and keep it in sport mode all the time as well. I don't really se a downside
