      03-26-2015, 02:27 PM   #1
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Battery Stabilizer for Velos Tune
Hey guys,
I need a battery stabilizer to flash my car with the Velos tune. Any Velos guys, or anyone for that matter, have a battery stabilizer i can borrow for the flash?
thanks
      03-26-2015, 02:44 PM   #2
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
"Borrow " one from Walmart , target ,autozone. If you know what I mean then.....
I didn't know I couldn't do that. But I did know I couldn't do that.
      03-26-2015, 03:22 PM   #3
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Hate to sound ignorant but to be honest i'm not even sure exactly what it is. Would you mind linking one here? I thought it was just a voltage regulator to ensure noise was kept to a minimum while flashing but now i'm not sure. i ordered one of these http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
i would rather get this done tonight so if you could post a link for onw i can pick up tonight that would be great.
Thanks
      03-26-2015, 03:34 PM   #4
zeroboot
Drives: 2011 X5M - sometimes
you just need one of these...i use it all the time for the exact same purpose...
http://www.walmart.com/ip/Battery-Te...arger/15779492
      03-26-2015, 03:38 PM   #5
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Omar specifically said not to throw a charger on there, but i'm seeing 4 settings. Any advice? Sorry for the ignorance.
      03-26-2015, 04:13 PM   #6
mitch808
Drives: 2012 X5 35i
Tenders are a little different than chargers, offering a trickle "charge," over a full charge that often spikes the battery cells to remove any calcification and other battery storage related issues.
A tender is proper, a charger *could* cause issues.
      03-26-2015, 04:28 PM   #7
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Perfect thanks guys, big help on this. Saved me a few bills in the process. Have a great one all!
      03-28-2015, 12:45 PM   #8
theonesupreme
theonesupreme's Avatar
11
Drives: X5M
It just for safety, i didn't Battery Stabilizer.
It will be done within 15-20 minutes.
X5///M WHITE, VELOS STAGE 2, AKRAPOVIC DOWNPIPE + FULL EXHAUST, KW V3 , VORSTEINER FRONT LIP + REAR DIFFUSER.......ETC
      03-28-2015, 12:51 PM   #9
sburke91
Drives: 2011 X5 50i
Your mileage can vary on this. I did my post-N63 base map extract on a brand new, fully charged battery, without the stabilizer, and it threw low battery warnings about 2/3 of the way in. The extract finished, but my blood pressure was a bit on the high side by the end.
Per Omar, writing takes a fair bit more power than reading, so the stabilizer is key on the write.
      04-02-2015, 02:22 PM   #10
speedwaywhite
Drives: 2011 X5M, Sapphire/Perf.Bambo
I used that exact model when I did my Velos tune with no issues. I suggest putting on that trickle charger prior to the install to ensure you have a full-loaded battery.
      04-06-2015, 06:47 PM   #11
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
The charging systems on the x5 sucks and with the wife's driving profile, I usually put the car on the tender at least once every 1-2 weeks for 12-24 hour stint. Has eliminated any battery warning issues.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      04-07-2015, 01:13 PM   #12
mhkm
The Doctor
mhkm's Avatar
14
Drives: 2007 E92 335i; 2013 E70 X5M
This is not my experience... my "read" took 80 minutes and I did not use any stabilizer or charger, but I do have a new 2013 with only 2000 miles on it and a fully charged battery. Near the end of the read, I got the "battery discharge" warning but it completed OK.
What he said....
I don't know about this... when I installed my Evolve tune on the 335, the read took 75 minutes, whereas the write only took 20 minutes... so if this is true, I would definitely recommend connect a stabilizer / charger to the battery.
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW.
