      08-08-2023, 02:03 PM   #1
fkashani
Drives: 2013 BMW X5
E70 X5 Turbo Upgrade!
Hello all,
My Turbo is failing on a 2013 X5. I am looking to change the Turbo and am wondering if there is an upgrade stage 1 or 2 that i can install instead of the OEM Turbo?
Has anyone done this on their 2013 X5?
      08-08-2023, 05:56 PM   #2
135ivert
Drives: E88 135i,E70 X5M,E93 M3
Originally Posted by fkashani View Post
Hello all,
Wouldn't you have the same options as other N55 owners? Now I'm curious even though I no longer have an N55.
      08-08-2023, 06:46 PM   #3
punisher12b
Drives: 2011 135i
you should be able to use a pure... fyi... if your EWG... which I think you are ... just get the stage 2.. the stage one isnt a big bump on ewg like it is the pwg...
      08-09-2023, 05:40 PM   #4
fkashani
Drives: 2013 BMW X5
You guys are too technical and have lost me. What I have found out is that the N55 engine in the X5 does not have the same turbo arrangement as an N55 twin turbo on a 5 series. The one on the X5 is attached to a manifold as one unit. this is the OEM part which is the direct replacement 11-65-7-636-423
https://www.bmwpartsnow.com/oem-part...er-11657636423
Most Stage one and Stage 2 turbos I have seen fit on the N55 twin turbo 5-series where the manifold and the turbo are separate components.
Any advice is greatly appreciated.
FK
      08-09-2023, 09:25 PM   #5
nodemgr
Drives: 2011 M3 ZCP Coupe 6MT
There is an X5 option here.
