      08-04-2023, 03:30 PM   #1
Arshad Osman
Arshad Osman's Avatar
South Africa
Drives: BMW M2 competition
2013 BMW X5M   [0.00]
2013 Bmw X5M E70
Good Day,
I would like to know about an issue that’s now become persistent on my X5M E70 has around 110000km.
The issue is a continuous misfire on cylinder no 6, the following was done,
1) Changed the coil pack
2) Changed the plug
3) Changed the injector on cylinder 6 and was coded to the car.
Yet it’s still misfiring, I’m leaning towards maybe a faulty O2 sensor but I’m not sure,
Your assistance in this matter will be highly appreciated.
Regards.
      08-07-2023, 04:36 PM   #2
Dave00
Drives: 2013 BMW X5M
Have you checked your injector on that cylinder? When changing your oil is it more saturated with gas as you could have a sticking injector that is causing a misfire. I would use a bore scope on that cylinder (pull the coil and plug) and visually inspect the cylinder to see if the injector is leaking down under pressure.
      08-14-2023, 03:39 PM   #3
Arshad Osman
South Africa
2013 BMW X5M   [0.00]
Thank you, that’s plan B just waiting for some parts from bmw.
