      02-04-2012, 03:36 PM   #1
matt_435xi
matt_435xi's Avatar
Drives: Perfomance Model 3
Question nail in tire, do i have to replace all 4??
i have a nail in 1 of my tires on my 2011 X5 35i Sport and i was told because it is an AWD SUV that i have to replace all 4 tires or i could damage the AWD system (transfer case)? is this true?
i was also told that if i did only replace the rears i had to stay with the same brand, because of the tread pattern, or i could damage the AWD system (transfer case).
please help, i really don't want to drop $2k on new tires after only 15k miles. this is the OEM Sport setup on the 35i so its a staggered set of 20" wheels.
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED*
      02-04-2012, 05:45 PM   #2
alegz
Drives: 2011 BMW X6M
No you don't have to replace all 4 tires, if you want to be cautious replace in pairs (2 tires) on the same axle. The rear and front tires don't match as is because they are staggered.
      02-04-2012, 05:54 PM   #3
matt_435xi
matt_435xi's Avatar
can I go with a different tread pattern (different brand RFT)?
i live in AZ so AWD is pointless for my wife, I just do not want to damage the car.
      02-04-2012, 06:05 PM   #4
alegz
yes you can use a different tread pattern, as long as you will be replacing both tires on the same axle. That is what I plan on doing, one of my front tires was cut. In the rear I'm keeping the original tires.
Are you leasing your car btw ?
      02-04-2012, 06:40 PM   #5
matt_435xi
matt_435xi's Avatar
yes I planned on replacing both rears.
not leasing.
      02-04-2012, 06:45 PM   #6
alegz
If you are not leasing there is no one to tell you what tires you can or can't use on your car.
      02-04-2012, 10:24 PM   #7
matt_435xi
matt_435xi's Avatar
right, like I said in my original post I didn't want to damage the AWD system.
      02-05-2012, 01:47 PM   #8
Mike van D
Mike van D's Avatar
Germany
18
Drives: SG X6 35i; MW e92 M3
Why don't you just replace the one with the nail with the same brand/size?
...just enjoying life.
      02-05-2012, 02:37 PM   #9
philipx6
Drives: 2012 bmw x6
I had 3 nails on my rear tire a month ago and had them removed .....why replace the whole things....unless u don't know what to do with your $
      02-05-2012, 02:55 PM   #10
TimZ
TimZ's Avatar
Albania
33
Drives: X5M
I got one nail in my tire and got the whole tire replaced. I was under wheel and tire insurance so I didn't have to pay a penny
      02-05-2012, 04:28 PM   #11
matt_435xi
matt_435xi's Avatar
for 2 reasons:
1. you never just replace 1 tire? all the tires have 16k miles on them, my car would be out of balance with 1 tire that is brand new.
2. the Dunlop tires on my X5 are ~$500 a piece, i can get 2 Bridgestone RFT tires for ~$500.
      02-05-2012, 04:29 PM   #12
matt_435xi
matt_435xi's Avatar
because the nail is in the shoulder of the tire, and would be nearly impossible to plug/patch. plus maybe dangerous if the tire shop was successful.
      02-05-2012, 04:29 PM   #13
matt_435xi
matt_435xi's Avatar
excellent, and that helps me how?
      02-06-2012, 01:54 AM   #14
LANDLORD
Turbo Engines are Fun
LANDLORD's Avatar
Drives: 2010 X6M Monte Carlo Blue
The important feature that must match between the front and rear tires is the overall diameter or the revolutions per mile. Because of the AWD system I would not mix and match tires, but if you purchased new tires for one axle, and the specifications said that the overall diameter and revolutions per mile matched the other axle, then I would think it could be OK. The other problem is the mileage on the older tires may alter the diameter, so there is a slight risk there, not to mention warranty issues.
I would not spend the money for the Dunlops, unless money was not a factor. The Bridgestone's are about 1/2 the cost, and are similar in performance.
One other note, if you drive these cars hard in the corners, the front tires will probably never last past 20K miles. The outside edges of mine are gone at 17K miles, but I found if I raise the tire pressure the outside edge wear is reduced somewhat, at the expense of the ride quality.
I have driven a lot of mountain roads at very high speeds exploring all the car has to offer, so tires are a cost of the good times in my book. I pass people just for fun and watching them disappear after a corner or two really makes we wonder what they are thinking about the big blue BMW that just screamed around them.
      02-06-2012, 07:38 AM   #15
matt_435xi
matt_435xi's Avatar
so can I run NEW Bridgestones in the rear and keep the OLD Dunlops up front?
the car is not riden hard, I just don't want to void warranty or break the transfer case; like I have said repeatedly in this thread.
      02-06-2012, 11:09 AM   #16
AndreyATC
AndreyATC's Avatar
Drives: 2016 Tesla Model X P90DL
Just think of it this way
1. You are going to have OEM spec tires in all 4 corners (Bridges and Dunlops are both OEM)
2. BMW swaps usually 1 tire when there is a problem, not all 4
3. There is a greater difference in diameter between wheels in staggered setup vs square setup, but it doesnt create a problem.
4. Diameter difference between wheels with new and old thread is so small, that it shouldnt even be bothered. Wear, for rear and front is not that even either
      02-06-2012, 07:18 PM   #17
matt_435xi
matt_435xi's Avatar
thanks for the info, i just bought 2 Bridgestone RFTs that will be installed later this week.
