      01-07-2012, 12:16 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Smile >> HP Autosport<< BMW 1M Ferodo DS2500 Brake Pads Member Pricing
Available now BMW 1M and M3 applications!
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, HPA would recommend the Ferodo DS3000 or DS1.11.
Front pads: $221.00
Rear pads: $213.00
Oder here:
https://hpautosport.com/product/ferodo-1m-brake-pads/
Best brake pad backing plate great money can buy:
https://www.amazon.com/gp/product/B0...9bf8ea5d022ad2
      01-09-2012, 08:07 PM   #2
M34lnch
Drives: 2017 BMW 440i
Hi,
Do you offer a brake pad that doesnt squeal? Quietness is primary for me, performance secondary. 2011 BMW 135i coupe.
Thanks.
2017 BMW 440i Blk/Blk-Blu Stitch | Auto | M-Sport | Nav
      01-10-2012, 03:55 PM   #3
HP Autosport
Drives: F80 M3
Originally Posted by M34lnch View Post
Hi,
Thanks.
We have Stoptech Street Performance Pads on the shelf ready to ship.
      02-11-2012, 09:44 AM   #4
M34lnch
Hi there,
One member suggested I take off pad sensor and ziptie it somewhere which would eliminate my brake squeaky noise problem. What do you think of this solution?
      02-11-2012, 11:42 AM   #5
HP Autosport
Drives: F80 M3
Hi there,
Pad wear sensor has nothing to do with it, unless your pads are so worn and your sensor is riding on your rotor. If that were the case, shouldn't you be replacing your pads, instead of just relocating the sensor?
      02-11-2012, 05:12 PM   #6
M34lnch
Correct, but I was told I have 9mm left.
      03-07-2012, 02:42 PM   #7
Kevin_russian
Kevin_russian's Avatar
Drives: 2011 bmw 135i
Is there a discount for 135i brake pads maybe? Currently looking for a good set of street/track pads and from what I've read so far ds2500 Ferodo are the ones to get....
      03-07-2012, 03:16 PM   #8
HP Autosport
Drives: F80 M3
PM sent!
      03-19-2012, 04:28 AM   #9
mpiligrim
M-addict
mpiligrim's Avatar
Russian Federation
Drives: M3 e92 Laguna seca, M5 f90 Com
So are they compatable with pad sensors? If yes, do I have to buy new ones each time I replace the pads?
Thank you!
In wroom I trust.
BMW M3 e92 Laguna Seca Blue '13
BMW M3 e91 Tourmaline Violet '10
BMW M5 F90 Comp Peridot Green '19
BMW 1M Valencia Orange '11 (sold)
      03-30-2012, 04:23 PM   #10
HP Autosport
Drives: F80 M3
Yes, they are compatible.
If the brake pad wear sensor light comes on, then new sensors are needed. Otherwise, you'll need to inspect them and make the call yourself. They do sometimes break when removed them from the old pads.
      04-11-2012, 12:36 PM   #11
HP Autosport
Drives: F80 M3
Ferodo DS2500
1M Street/HPDE/Track Day pads in stock!
Don't ruin your street pads any longer!
FREE Stoptech STR600 brake fluid with any brake pad purchase!
      06-04-2012, 10:45 PM   #12
1&done
1&done's Avatar
Drives: 2011 VO 1M
When will they be in stock for 135?
///1M #643 of #740
      06-05-2012, 11:37 AM   #13
HP Autosport
Drives: F80 M3
They were back in stock, but sold quickly.
      06-05-2012, 03:48 PM   #14
M34lnch
HP Autowerks,
What is your current recommendation (brake pads) for a 2011 BMW 135i coupe?
I am not interested in tracking, just something inexpensive to replace my squeaky brakes.
      06-14-2012, 11:53 PM   #15
HP Autosport
Drives: F80 M3
HP Autowerks,
If you don't track, Stoptech Street Performance or Porterfield R4S pads.
      09-24-2012, 11:47 PM   #16
toni8284
toni8284's Avatar
Drives: N/A
2011 BMW 1M  [10.00]
2016 M3  [0.00]
HPA,
I installed the pads last week which I bought from you guys.
But my installer told me the back sensor cant put them back on the pad, any idea or suggestion?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD)
2016 F80 AY M3 (SOLD)
2014 F10 M5 LCI (SOLD)
2011 VO 1M (SOLD)
      09-25-2012, 01:11 PM   #17
HP Autosport
Drives: F80 M3
Originally Posted by toni8284 View Post
HPA,
Sometimes you will have to install the sensor on the outboard pad, instead of the inboard pad. As with many clubsport or race pads sometimes the sensors aren't used at all.
I will make sure Ferodo is aware of this issue.
      06-05-2014, 08:57 PM   #18
HP Autosport
Drives: F80 M3
Bump!
      01-20-2016, 12:12 PM   #19
HP Autosport
Drives: F80 M3
bump
      01-22-2016, 03:32 PM   #20
Tom303
Tom303's Avatar
11
Drives: VO 1M
What is the group pricing?
      01-25-2016, 12:47 AM   #21
HP Autosport
Drives: F80 M3
The price actually went up again.
Price listed in the original post is the member pricing.
      02-12-2016, 03:24 PM   #22
HP Autosport
Drives: F80 M3
Bump
1addicts
