      03-07-2020, 12:59 AM   #1
riozheng
riozheng's Avatar
Drives: 2012 X5 35i Sport Activity
Question
Just crossed 100k yesterday and the Parking warning on 😂😂
It happened with the brake engaged. I manually released the brake so that I can drive it home. However, the warning sign stays on. I've tried to soft reset it (5sec push&pull), and also pulled out the fuse. Not working on both ways. I asked a mechanic to read the ECU and got the 600E and 6011 error code...
I've followed the steps as the link below:
https://www.youcanic.com/wiki/bmw-el...ke-malfunction
Symptoms on my case:
BMW parking brake malfunction
Yellow PARK light stays on all the time
Fault code 6011 and 600E in ECU EEPROM DATA
Park brake light will not go off, even when the car is moving.
Orange Brake Light ON when starting the car.
Parking brake can't be engaged.
Is that possible to fix it before open the brake actuator?
Thanks!
2012 X5 35i Sports Activity
      03-07-2020, 08:18 AM   #2
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
Nope. Buy a new actuator. Very Common failure on e70s cars tons of threads out there. You can buy a clone off of eBay for $300. Install takes a few hours. Done this one before.... you can do an ecu code clear and get rid of the error, but if you use it, the error will come back.
Theses power actuated brakes are so stupid in modern cars. Take a simple reliable manually operated cable and peddle or handle and replace it with a failure prone electrical system that costs a ton of money to fix. For what end... can’t even use the parking brake to do a j turn anymore,,,
      03-07-2020, 11:15 AM   #3
riozheng
riozheng's Avatar
Theses power actuated brakes are so stupid in modern cars. Take a simple reliable manually operated cable and peddle or handle and replace it with a failure prone electrical system that costs a ton of money to fix. For what end... can't even use the parking brake to do a j turn anymore,,,
sounds like the only way is replacing the module…
Yeah…I like the old way, reliable and fun. Than you!
      03-09-2020, 07:27 AM   #4
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Thanks!
How did you release it manually?
      03-09-2020, 07:47 PM   #5
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
its in the manual, but there is a plastic tool in the trunk under the floor, and on the driver side behind the trunk panel is the release cable. Use the tool or pliers to pull it.
      03-10-2020, 12:08 AM   #6
Dawgz
2022 M4 Comp Xdrive
1016
Ah I see. Thanks!
Apparently they sell metal gears to fix the unit
      03-12-2020, 07:42 AM   #7
riozheng
riozheng's Avatar
Thanks!
As Thecastle said, you can find the tool and release cable in your trunk. You need pull it really hard until you heard a sound. Pull it gently!
      07-10-2023, 12:03 PM   #8
werdn
werdn's Avatar
656
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
Did you end up replacing it with an Ebay unit?
      08-04-2023, 08:22 PM   #9
osik88
osik88's Avatar
Drives: BMW X5 F15
Any idea how to code it or program it to the car after replacing the actuator?Thanks
      08-05-2023, 10:12 AM   #10
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
osik88 You shouldn't have to reprogram anything if you're just replacing the actuator.
****EDIT****
TIS references reprogramming when replacing the actuator.
In ISTA the procedure is as follows:
-Service Functions
-Chassis and Suspension
-Parking Brake
-Initial Operation/Functional Check
      08-05-2023, 04:59 PM   #11
osik88
osik88's Avatar
Drives: BMW X5 F15
Figure it out Replaced both fuses all good now Thanks for your help
      08-09-2023, 08:51 AM   #12
plebeiu
Drives: BMW X5 2012, Subaru XV 2018
Hello guys... small question:
I recently got myself a 2012 e70 facelifted unit (european diesel, no DPF or that nonsense)...
this LSI have revised parking break actuators or it is the same thing (as in, it will eventually fail)?
      08-09-2023, 10:16 AM   #13
jbash87
2006 BMW M5  [10.00]
If by LSI you mean LCI (Life Cycle Impulse. 2010 and newer) then yes. They will still have issues. Mine is a 2012 and will fail again. I've been repairing mine each time but I may not be able to to repair it again.
      08-10-2023, 10:40 AM   #14
plebeiu
yes LCI sorry.
thank you for your reply.
