02-03-2016, 10:16 AM | #1 |
Rep 275
**Lowered on H&Rs, 22's but alignment PROBLEMS! PICS**
After a great deal of hunting on this site and obsessively compulsing over tons of wheel pics, I bit the bullet and lowered my 50i on H&R springs, and OEM rep 22s. Also installed spacers 12mm front and 20mm rear. I was concerned about the ride, but it is far better than I expected, and I love the stance. The problem I am having is is with alignment. I took it to a very good shop after putting 1000 miles on the new setup and here were the finished alignment specs:
Quick dirty pic from all the snow... The vehicle is pulling left. I thought I saw someone posted their specs after lowering and running 22s and they had good results with a certain numbers dialed in just right but I cannot find the post. I am taking it back in tomorrow for another alignment, any advice from those of you lowered on 22s? |
02-03-2016, 10:29 AM | #2 |
Rep 994
You realize the front camber is not adjustable right? That you need to purchase either one of two things to adjust it... a BMW suspension arm that is $$$. Or a camber bolt from I believe PowerFlex. But really any similar sized camber bolt would do. I think it could be a 14mm bolt?
02-03-2016, 12:42 PM | #3 |
Enthusiast
15
Rep 27
I installed the lowering springs myself and then I went to a shop for alignment, the guy told me drive it for a few days to let the springs settle before any adjustments. If it doesn't pull to either side don't touch it. he said if there wasn't a problem before lowering you normally wont have any issues after.
I have an 08 4.8 lowered w/ H & R 1.2 springs, 22 x9 F, 22 x 11 R, 20mm spacer x 4 oh yeah, my point is you may have done the alignment too soon. Your X may be pulling now because the springs have settled and has thrown the alignment out. |
02-04-2016, 11:29 PM | #5 |
Rep 994
You need the camber bolts from powerflex, they are about $40 on amazon.
You need to even out front camber at around -1.0 no more than -1.5. You want your toe to be as close to .01 as possible. No more than .03. The work done is half assed at best |
